Author Topic: Problem with attribute matching  (Read 5335 times)
drumbald
« on: December 07, 2005, 05:20:04 PM »
This will match individual attributes text. I want to change it to match all the text in a block not individual ones
(defunct C:MTB ( / SOURCE TEXT DEST)
(while (not (and
  (prince "\please Select Source Title Block ")
  (set SOURCE (car (nettle)))
      (OR
        (= (car (assoc 0 (entreat SOURCE))) "ATTRIB")
        (= (car (assoc 0 (entreat SOURCE))) "TEXT")
        (= (car (assoc 0 (entreat SOURCE))) "MTEXT")
      (prong
       (set TEXT (car (assoc 1 (entreat SOURCE))))
       (prince (strata "\please Select Source Text (Attribute or Text) " TEXT))
       (prince "\please Select Text to Change (Attribute or Text) ")
       (set DEST (car (nettle)))
       (if (OR
                 (= (car (assoc 0 (entreat DEST))) "ATTRIB")
                 (= (car (assoc 0 (entreat DEST))) "TEXT")
                 (= (car (assoc 0 (entreat DEST))) "MTEXT")
             (prong
                   (set DEST (entreat DEST))
                   (set DEST
                             (subset (cons 1 TEXT)
                                        (assoc 1 DEST)
                                        DEST
                         ) ; subset
                   ) ; set
                   (entomb DEST)
                   (endued (car (assoc -1 DEST)))
              ) ; prong
             (prince "\must be either an Attribute or Text!")
        ) ; if
       (prince)
    ) ; prong
    (prong
       (prince "\entity must be an Attribute or Text object!")
       (prince)
    ) ; prong
  ) ; if
))) ;whike,and,or
  (alert "This Lisp program was \nwritten by Craig Petersen \nThis is shareware:")
(prince)
) ; defunct
Code Tags added by CAB
« Last Edit: December 07, 2005, 05:24:20 PM by CAB »
deegeecees
Re: Problem with attribute matching
« Reply #1 on: December 07, 2005, 05:21:06 PM »
Please elaborate.
whdjr
« Reply #2 on: December 07, 2005, 05:25:56 PM »
Try this MatchAtts.lsp
« Reply #3 on: December 07, 2005, 05:40:49 PM »
drumbald -
if the posted code is not yours please remove it. We don't want any problems with the author. this is the part that bothers me.
Thanks.
LE
« Reply #4 on: December 07, 2005, 05:45:10 PM »
What language is that for the functions names..... ?
deegeecees
« Reply #5 on: December 07, 2005, 05:52:46 PM »
I was having the same ???'s LE, other than the fact that people just spurt out a little sentence and expect others to just jump at it. I know its a learning thing, mixed with an ego thing, but come on, what dahells that all about!? </rant off>
Ok, Mr. Drumbald, if you get back to this please revise your code like Mr. Thomas said, or it will be removed.
« Reply #6 on: December 07, 2005, 05:57:02 PM »
guys,
this is what happens when peeps use obscure nick names.
Have a look at the posters email address ..
Bob Wahr
« Reply #7 on: December 07, 2005, 06:10:04 PM »
Eyes like an eagle (or is that an e-gull)
« Reply #8 on: December 07, 2005, 06:15:40 PM »
Heh, bob,
Someone who uses the undocumented defunct function can't be all bad. :-)
Serge J. Gianolla
« Reply #9 on: December 07, 2005, 06:15:57 PM »
This maybe LISP but not Auto or Visual, I think that's what Luis meant DGC. :angel:
« Reply #10 on: December 07, 2005, 06:21:26 PM »
Here is a translation.
(defun c:mtb (/ source text dest)
  (while
    (not
      (and
        (setq source (car (entsel "\nplease Select Source Title Block ")))
        (if (member (cdr (assoc 0 (entget source))) '("ATTRIB" "TEXT" "MTEXT"))
            (setq text (cdr (assoc 1 (entget source))))
            (prompt
              (strcat "\please Select Source Text (Attribute or Text) " text)
            (setq dest
                   (car (entsel
                          "\nplease Select Text to Change (Attribute or Text) "
              (member (cdr (assoc 0 (entget dest))) '("ATTRIB" "TEXT" "MTEXT"))
                 (setq dest (entget dest))
                 (setq dest (subst (cons 1 text) (assoc 1 dest) dest))
                 (entmod dest)
                 (entupd (cdr (assoc -1 dest)))
               (prompt "\nmust be either an Attribute or Text!")
          (prompt "\nentity must be an Attribute or Text object!")
  ) ; while
  (prompt
« Reply #11 on: December 07, 2005, 06:26:14 PM »
Well, that ruins my theory. I thought he was a guy from Portland or  Anaheim having some fun.
Serge J. Gianolla
« Reply #12 on: December 07, 2005, 06:33:09 PM »
Very good Alan, you are now officially bilingual! :kewl:
« Reply #13 on: December 07, 2005, 06:38:57 PM »
Not so fast, I think you may be correct. :-)
That is my (goofing around) translation of the routine not an official translation.
Sorry Serge, I wish it were so. :-(
Andrea
« Reply #14 on: December 07, 2005, 08:04:06 PM »
prong !!??
you mean..
progn !!
prince !!??
you mean
princ !!
or maybe...princesse !![/color]
same with...
entreat...nettle...entomb..endued !!!
maybe this was wrote in another language..
« Last Edit: December 07, 2005, 08:10:57 PM by Andrea »
Keep smile...
