Hi Mark
I used to use it a lot with DCL programming. Kept a list of key names. Then kept a global associated list of key names and values for each dialog run. Using set made it easy to produce variables with the same 'name' as the key.
I've been using ObjectDCL for a while now so dont use that methodology as much, and mainly use set now when reading variable names and values from ini type files or databases, or as indicated by MP ^^
