Author Topic: Mtext wrap or hard return?  (Read 15455 times)
hudster
Re: Mtext wrap or hard return?
« Reply #15 on: December 09, 2005, 03:46:18 AM »
I had a difference of opinion about this with another draffie.
Whats the points of Mtext having a word processor type interface if you use hard returns for notes?
It defeats the purpose.
He uses them in leaders as well, I personally never use a hard return and instead use the width to control the leader text.
M-dub
« Reply #16 on: December 09, 2005, 11:50:23 AM »
The only time we use Mtext is well, when there are multiple lines of text such as notes. :)
 One of my pet peeves is when I find strings like 3-FI-1234 as Mtext.
pmvliet
« Reply #17 on: December 09, 2005, 12:46:30 PM »
I use hard returns in this instance for note sheets:
1. This is a test to see what happens
    When you want to go onto a second line with hard returns.
2. With word wrap, your second line will
start right under the 2. and I don't like that look.
To avoid that, you have to have your number as one entitiy
and then your information as another...
Pieter
M-dub
« Reply #18 on: December 09, 2005, 12:52:12 PM »
I used to agree with you, Pieter, but I'm an Mtext convert.  :)
Using a hard return isn't too bad for original creation, but for the next guy (or YOU) who has to modify the note, it can be a real pain in the butt!
pmvliet
« Reply #19 on: December 09, 2005, 12:53:56 PM »
M-dub, that is mtext, do you think I'm using dtext?
M-dub
« Reply #20 on: December 09, 2005, 12:59:46 PM »
Oh, sorry, yes I did.
My mistake...carry on!  :)
pmvliet
« Reply #21 on: December 09, 2005, 01:07:53 PM »
The only occasion where I use text is like where you stated "short strings of text" such as X-001
If my chance I need to add a second line, I have "TT" set to convert to mtext.
Dinosaur
« Reply #22 on: December 09, 2005, 01:11:49 PM »
Be sure to look for the changes in MText with your next upgrade.  Tabs and numbered list functions have already been added.  Because of these issues, I almost overlooked them in favor of my old alternative methodology.
pmvliet
« Reply #23 on: December 09, 2005, 02:30:12 PM »
that is a good point to mention. I'll keep that in mind, but much of what I do/have done gets tossed around, translated and everything else imaginable. So I tend to keep things as simple as possible so that when it does get translated or something like that, the files are much cleaner.
I've just been the person who has had to deal with files that are really messed up.
Pieter
Kate M
« Reply #24 on: December 09, 2005, 04:39:14 PM »
In 2004, you can set a paragraph indent that eliminates the need for hard returns in numbered lists.
dtkell
« Reply #25 on: December 09, 2005, 05:34:23 PM »
Usually fit with text wrap and utilize hard returns for delineating notes.
\"What sane person could live in this world and not be crazy?\" -Ursula K. Le Guin
