Author Topic: Adding Objects to the DrawingDataBase  (Read 15621 times)
Re: Adding Objects to the DrawingDataBase
« Reply #15 on: December 10, 2005, 10:42:51 PM »
Nice Work Kerry
Indeed, very nice.  I really like the idea of breaking the steps down into something easy to follow :)
Can't claim credit for it Bobby, in principle that's straight out of the AutoCAD Docs  .. one of the PowerPoint presentations if I recall.
How was AU for you this year ? Hope you had a good attendance .
Just reading one of your AU2004 Handouts Bobby<CP24-2> .. see that you do  'like the idea of breaking the steps down ..' :-)
Bobby C. Jones
  • Cry havoc and let loose the dogs of war.
« Reply #16 on: December 12, 2005, 10:12:51 PM »
Ack!  I remember that one :-)  I didn't get good vibes from it.
However, it went *much* better this year.  And it had a lot more code examples.  I'll see if I can get them up on the board this week if anyone is interested.
Bobby C. Jones
Swift
« Reply #17 on: December 13, 2005, 07:21:58 AM »
I'm always interested in a good read!
« Reply #18 on: December 13, 2005, 10:27:44 AM »
Yeah, me too, Great offer Bobby.
« Reply #19 on: January 08, 2006, 07:13:07 PM »
Playing with the next step .. adding multiple Entities to the Database in one Transaction
Any Comments ?
The Tester :
using System;
using System.Diagnostics;
using System.Collections;
using AcadApplication = Autodesk.AutoCAD.ApplicationServices.Application;
using AcadDatabase = Autodesk.AutoCAD.DatabaseServices.Database;
using AcadEditor = Autodesk.AutoCAD.EditorInput.Editor;
using AcadTransaction = Autodesk.AutoCAD.DatabaseServices.Transaction;
using AcadTransactionManager = Autodesk.AutoCAD.DatabaseServices.TransactionManager;
using KdubTest.Util;
using Autodesk.AutoCAD.Colors;
// NOTE: LoaderLock exception break toggled OFF to suit vs2005 in AC2006. kwb
[assembly: CommandClass(typeof(KdubTest.TestClass))]
namespace KdubTest
    public class TestClass
        [CommandMethod("TestCircles", CommandFlags.Modal)]
        static public void TestCircles()
            AcadDatabase db = AcadApplication.DocumentManager.MdiActiveDocument.Database;
            // These points are in World UCS, irrespective of current UCS
            // Look at Matrix translations
            Point3d centerPoint_01 = new Point3d(70.0, 70.0, 0.0);
            Vector3d normalZ = new Vector3d(0.0, 0.0, 1.0);
            double radius_01 = 20.0;
            double radius_02 = 30.0;
            double radius_03 = 40.0;
            double radius_04 = 50.0;
            double radius_05 = 60.0;
            double radius_06 = 70.0;
            Circle circle_01 = new Circle(centerPoint_01, normalZ, radius_01);
            Circle circle_02 = new Circle(centerPoint_01, normalZ, radius_02);
            Circle circle_03 = new Circle(centerPoint_01, normalZ, radius_03);
            Circle circle_04 = new Circle(centerPoint_01, normalZ, radius_04);
            Circle circle_05 = new Circle(centerPoint_01, normalZ, radius_05);
            Circle circle_06 = new Circle(centerPoint_01, normalZ, radius_06);
            Tbl.AddEntities(db, new Entity[] {circle_01, circle_02, circle_03, circle_04, circle_05, circle_06 });
From the Library <snipped> :
using System;
namespace KdubTest.Util
    public sealed class Tbl
        public Tbl()
        public static ObjectIdCollection AddEntities(Database db, params Entity[] ents)
            ObjectIdCollection collection = new ObjectIdCollection();
            using (Transaction tr = db.TransactionManager.StartTransaction()) {
                BlockTable bt = (BlockTable)tr.GetObject(db.BlockTableId, OpenMode.ForRead, false);
                BlockTableRecord btr = (BlockTableRecord)tr.GetObject(db.CurrentSpaceId, OpenMode.ForWrite); ;
                Entity[] entityArray = ents;
                foreach (Entity ent in ents) {
                    collection.Add(btr.AppendEntity(ent));
                    tr.AddNewlyCreatedDBObject(ent, true);
                tr.Commit();
            return collection;
Glenn R
« Reply #20 on: January 08, 2006, 07:48:11 PM »
Kerry,
From my quick look, nicely done. The only thing I would add would be to check the validity of the incoming ents array.
if null or length == 0, return null immediately.
Other than that, which is just personal, it looks solid.
Cheers,
Glenn.
« Reply #21 on: January 08, 2006, 08:07:44 PM »
Hi Glenn
I have a note on my version to test for null
I did have a test for if ents.length == 0 return null; which worked fine, but still needed to test each array item for null, 'cause it spat the dummy if any of the items were null when I tested it.
I think the code is about as tight as it will ever get.
