As I'm sure most know, sometimes the region command will reject "degenerate" or "unsupported" objects and then fail to create a region. The problem is then to try to find the offending object -good luck! - if it's a large, convoluted series of curves, perhaps containing a spline or 2, and/or maybe an elliptical arc. Wouldn't it be great if, upon rejecting an object as either degenerate or unsupported, that the object would then be highlighted? That could save the user a lot of time trying to fix the problem.
Has anybody seen or written any code that could accomplish this? Or perhaps a 3rd party app?
