Author Topic: There's got to be a better way  (Read 10663 times)
CADaver
Re: There's got to be a better way
« Reply #15 on: April 06, 2006, 08:38:10 AM »
Okay guys, remember us slow folks are still around, and had I known I'd have needed those brain cells, I'd have been kinder to 'em in my youth.  Michael, when you have time, could you spread out FORFUN with a little explanation for me.  I'm trying to reach around it and get a grip on it for application.  :|
« Reply #16 on: April 06, 2006, 09:20:22 AM »
Does this help?
(defun ForFun ( / data result )
    (while (setq data (tblnext "layer" (null data)))
      ;; tblnext when used this way, with the `data' var not valid,
      ;; {the var has not been initialized yet so `(nul nil) will return `T}
      ;; will retrieve the first entity in the database.
      ;; so this loop will continue thru the entire dwg database.
        (setq result
            (cons
                (mapcar
                  '(lambda (key) (cdr (assoc key data)))
                  '(2 62 6)
                result
Does that help?
« Reply #17 on: April 06, 2006, 09:42:53 AM »
How about this Chuck, does this illuminate the underpinnings?
(defun c:sample ( / foo data keys )
    (defun foo ( data keys / result )
        ;;  the core algorythm
        (setq result
            (mapcar
                keys
        ;;  print out the original data
        (princ
            (strcat
                "Data = "
                (vl-prin1-to-string data)
                "\n"
        ;;  print out the keys used to filter the data
        (princ
            (strcat
                "Keys = "
                (vl-prin1-to-string keys)
                "\n"
        ;;  print out the filtered data
        (princ
            (strcat
                "Filtered data = "
                (vl-prin1-to-string result)
                "\n\n"
    ;;  set up some simple data
    (setq data
            (1 . "Chuck")
            (2 . "John")
            (3 . "Mark")
            (4 . "Michael")
            (5 . "Randy")
    ;;  now filter using different keys
    (foo data '(1))
    (foo data '(1 2 3))
    (foo data '(1 3 5))
Output --
Data = ((1 . "Chuck") (2 . "John") (3 . "Mark") (4 . "Michael") (5 . "Randy"))
Keys = (1)
Filtered data = ("Chuck")
Keys = (1 2 3)
Filtered data = ("Chuck" "John" "Mark")
Keys = (1 3 5)
Filtered data = ("Chuck" "Mark" "Randy")
« Reply #18 on: April 06, 2006, 10:04:38 AM »
Well I'm too slow as usual, but here is my expiation attempt.
  ;;  (while ..) - Returns The most recent value of the last expr. therefore in this case
  ;;  it will return the 'result'
           ;;  (tblnext table-name [rewind]) - get the next related item in the table
           ;;  [rewind] If present and not nil, the first entry in it is retrieved
           ;;   in this case (null data) returns T the first time through thus causing
           ;;   the first record to be returned, thereafter it is nil & steps through the table
        (setq result  ;  collect the result each time through the loop
            (cons        ;  (cons new-first-element list-or-atom)  make a list
                         ;   because 'result' is nil the first time through and nil is considered
                         ;   a list, 'setq result' gets the first list from the mapcar and makes
                         ;   it a list,  ((<mapcar output>)) on subsequent loops it becomes
                         ;   ((<mapcar output3>)(<mapcar output2>)(<mapcar output1>))
                (mapcar     ;  Returns a list of the result of executing a function with the individual elements of a list
                            ;  In this case each item from the list (2 62 6) is fed to the lambda one at a time
                            ;  first 2, then 62 and finally 6
                   '(lambda (key)    ;  Defines an anonymous function
                      (cdr (assoc key data)) ;  This function you know, assoc returns the list or pair if a match is found
                                             ;   if 'data' is ((0 . "LAYER") (2 . "0") (70 . 0) (62 . 7) (6 . "Continuous"))
                                             ;   (assoc 2  data )  returns (2 . "0") which is layer "0"
                                             ;   (cdr (2 . "0"))  returns  "0"
                   '(2 62 6)  ;  this is the list in the mapcar statement
                result    ; this the list in the cons statement
<spelling>
« Last Edit: April 06, 2006, 12:21:03 PM by CAB »
CADaver
« Reply #19 on: April 06, 2006, 12:12:27 PM »
whoa!  I learned more from the last three posts than I have in the last year... now I need a nap.  :lol:
Realizing that the data var was not valid returning a T, was like "Well of course why didn't I know that". :ugly:  And it took me a minute to get around the (mapcar (lambda to pull the layer, color and linetype (2 62 6), but I think I got it.
KEWL, Thanks guys.
« Reply #20 on: April 06, 2006, 12:58:19 PM »
Mapcar-lambda is easy. Here, watch:
Mapcar: Do <something> to every item in a list.
Lambda: Same as defun but no `name' ...A Lambda is list of process' just like a formal(named) procedure.
Demonstrations:
Mapcar can be remade like this (For the sake of this convo just conern your self with the basics.):
Demonstration will demonstrate the process of printing each item in a list.
(defun print-it (lst)
   (if (null lst)
   ;; if the list is `empty' or `nil'
     nil
   ;; return `nil'
   ;; otherwise
        (princ (car lst))
   ;; print the first item in the list
        (print-it (cdr lst))
   ;; strip off the first item(cause we just printed it) and go thur again.
lambda is even easier to unerstand. Since it is nothing more then a formal procedure without a name it can be defined on the fly(so to speak) or at the point of use/need.
( (lambda () (1+ 2)) )
Will return what? ...3. Good.
So, a Mapcar-Lambda statment is saying nothing more then: "Preform <this> function on each and every item in a list."
How's that? Is the process a bit more clear?
CADaver
« Reply #21 on: April 06, 2006, 01:57:17 PM »
Got it, thanks.  I now have a whole new realm of applications buzzing in me punkin' head.
« Reply #22 on: April 06, 2006, 02:21:19 PM »
BTDT -- I can recommend a good sleep clinic.
CADaver
« Reply #23 on: April 06, 2006, 02:47:24 PM »
nah, at my age excitement is self-limiting, 10 minutes of thinkin', and I gotta take a nap.
I said "THINKIN'", now.
« Reply #24 on: April 06, 2006, 02:53:10 PM »
<mutter> preemptive <expletive> <grumble>
LE
« Reply #25 on: April 06, 2006, 03:39:47 PM »
(setq lst nil)
(while (setq item (tblnext "LAYER" (not item)))
  (setq lst (cons (list (cdadr item) (cdar (cdddr item)) (cdadr (cdddr item))) lst)))
Rev = correction, forgot the first layer... one more time.... another change made... Hey.... I think I need the new lisp book by Mark soon!!!!!
« Last Edit: April 06, 2006, 04:00:52 PM by LE »
« Reply #26 on: April 06, 2006, 03:43:53 PM »
(setq lst nil)
(tblnext "LAYER" t)
(while (setq item (tblnext "LAYER"))
That's just evil Luis.
« Reply #27 on: April 06, 2006, 03:57:16 PM »
what  :evil:  :evil:  :evil:
:lmao:
At least it wasn't
(setq lst nil)
(tblnext "LAYER" t)
 (setq
  lst
  (list
   (cdr
    (car
     (cdr item)
   (cdr
    (car
     (cdr
      (cdr
       (cdr item)
   (cdr
    (car
     (cdr
      (cdr
       (cdr
        (cdr item)
ps
if that is a bad code I apologize... have been a looooooooong time, that I do not wrote anything in autolisp....  :cry:
Not at all.  Just thought it was funny, see above I did before you posted this one.
« Reply #28 on: April 06, 2006, 03:59:20 PM »
Oops.  Forgot the "cons" part, but you get the idea.  All in good fun.
« Reply #29 on: April 06, 2006, 04:08:27 PM »
I like seeing the (cadar... stuff, it just seems that people don't use it very often.  That is why I was said that you were evil (joking of course) because people don't seem to grasp it that easily.
 :angel:
