Author Topic: retrieving attribute values  (Read 5871 times)
Andrea
Re: retrieving attribute values
« Reply #15 on: December 01, 2005, 10:49:43 AM »
Please note I am not picking on you personally.
There are certain logic rules to follow when writing computer programs, you've just missed a few here.
Kerry, comment like your's give me nitro to improve my programs...thanks.  :roll:
also, from your comment I have modified the routine, could you comment this one ?
just to be sure...?
(defun c:getbat (/ edata attdata eb1 eb2)
(setq bname (getstring "Enter your block name : "))
  (if (ssget "X" (list (cons 0 "INSERT") (cons 2 bname))) (getdata)
    (alert (strcat "No block named " bname " was detected on this drawing."))
  );;if
(defun getdata ()
(setq edata (entget (ssname (ssget "X" (list (cons 0 "INSERT") (cons 2 bname))) 0)))
 (setq attdata (entget (entnext (dxf -1 edata))))
 (if (= (cdr (assoc 0 attdata)) "ATTRIB")
    (setq x T)
    (setq edata (entget (entnext (dxf -1 edata))))
  (while x
(setq eb1 (dxf 1 edata));; = Attribute Value
        (setq eb2 (dxf 2 edata));; = Attribute TAG
        (alert (strcat "Tag = " eb2 "\nValue = " eb1))
        (if (eq (dxf 0 edata) "SEQEND") (setq x nil))
    );;while
   );;progn
(alert "This block is present but miss attribute.")
  );;if
(setq bname nil)
(defun dxf (code elist)
(cdr (assoc code elist))
);defun
Keep smile...
« Reply #16 on: December 01, 2005, 11:01:42 AM »
sure, one item at a time ..
Do you know what the DXF 66 does ?
(setq ss (ssget "_X" '((0 . "INSERT") (66 . 1) (cons (2  blockNameToFind)))))
Think about passing the getdata function the  blockNameToFind
Think about returning the required info to the calling routine ;
ie : (setq val (getdata blockNameToFind) )
Think about localising your variables.
Think about testing the length of the selectionSet and advising the user that there is more than ONE block in the drawing.
Andrea
« Reply #17 on: December 01, 2005, 12:20:37 PM »
Thanks Kerry..
I'll think a little bit more..  :lmao:
Keep smile...
« Reply #18 on: December 02, 2005, 05:22:42 PM »
How did you go ? ?
