Hi all,
I'm trying to found how can I get a list of all ACAD Environnement..
(getenv "PrinterStyleSheetDir")
(getenv "PrinterConfigDir")
etc....
i've made a search in AutoCAD..but..nothing..
thanks.
Hi Andrea,
I tested this and have a got the following results:
_$ "C:\\Documents and Settings\\admin\\Application Data\\Autodesk\\AutoCAD 2005\\R16.1\\enu\\Plot Styles"
_$ "C:\\Documents and Settings\\admin\\Application Data\\Autodesk\\AutoCAD 2005\\R16.1\\enu\\plotters"
I think your problem is because of in the current profile that you use
these variables does not exist
Let you change profile in your drawing on another one and try to get
these both again
Thank you
Fatty
Thanks Fatty,
But in fact no,
I just need to have al Environnement LIST variables...
eg:
with (getenv "ACAD")
you can get all directory folder in your AutoCAd search path...
but I need to have a list of all Environnement...
like:
"ACAD" "PrinterStyleSheetDir" "PrinterConfigDir" ....and they other who I don't realy know.
eg: If I need to get the directory for the PMP file....what is the environnement variable ?
thanks.
