Author Topic: layer dia box 'gone awol'  (Read 4556 times)
M-dub
Re: layer dia box 'gone awol'
« Reply #15 on: November 25, 2005, 10:54:31 AM »
did you try changing cmddia, then changing it back?
Dinosaur
« Reply #16 on: November 25, 2005, 10:55:44 AM »
Not with the repair, although it is not a bad idea to copy them somewhere safe just in case.  The only thing you should have to do is any add any service pack that had been applied.
Big G
« Reply #17 on: November 25, 2005, 10:58:39 AM »
m-dub yeah dude, pfaffed around with changing a few of the sysvars and changing them back....it still looks like the dia is appearing 'somewhere' just not on the screen area.
Ive also tried changing the size down to 640 and seeing what happens but its still not there?
Ill try a repair on it......first thing monday haha!!
Ill post up the results of it.
Ta again folks....Though if anyone has any further ideas please keep em coming!! curious to know if theres a way to "reset" the dia's
I thought i seen the light at the end of the tunnel. But it was just someone with a torch bringing me more work.
"You have to accept that somedays youre the pigeon and  somedays youre the statue"
M-dub
« Last Edit: November 25, 2005, 11:04:28 AM by M-dub »
M-dub
« Reply #19 on: November 25, 2005, 11:01:42 AM »
What do you see in the command history?  (F2)
Big G
« Reply #20 on: November 25, 2005, 11:06:46 AM »
Command: '_layer, but ONLY after i Esc out of it.
According to the communication center in 2K6 im up to date.
Will i post a setvar <?> printout?
M-dub
« Reply #21 on: November 25, 2005, 11:08:28 AM »
What do you mean?  This works or doesn't?
I don't know...Will you?  ;)
Go ahead!
Big G
« Reply #22 on: November 25, 2005, 11:14:41 AM »
Sorry m-dub it doesnt work.....get nothin at the cmd line....and the '_layer only appears asfter i esc from the command
Sysvar Settings below
http://www.theswamp.org/lilly_pond/big_g/sysvar%20settings.txt
Dinosaur
« Reply #23 on: November 25, 2005, 11:16:13 AM »
Did you try setting the display so autocad was NOT maximized?  If not try doing so and then minimize the autocad window or move it around.  At times, this will expose renegade boxes or even the command line when it gets lost.
A free hint - if you only have one monitor run autocad this way and narrow up the screen a few pixels.  You can then have large dialog boxes like "properties" in the strips always available as a flyout without worrying about them docking or covering your working area.
Big G
« Reply #24 on: November 28, 2005, 06:21:42 AM »
Had to do a reinstall...it 'seems' to be working for the meantime...
Ta again for the replies folks...
Gordy
« Reply #25 on: November 28, 2005, 08:48:06 AM »
Big G,
I had this same problem on one of the CAD stations here. The problem showed up on Vanilla Acad after installing LDD 2005 w/ Civil Design. A  complete uninstall\reinstall was the only thing that fixed the problem here as well.
Ron
Bob Wahr
« Reply #26 on: November 28, 2005, 02:54:38 PM »
[guess]It has been moved off screen[/guess]
Try increasing your monitor resolution as high as it will go (hopefully it's not already there) and you might find it.
Bob Wahr
« Reply #27 on: November 28, 2005, 03:01:19 PM »
The dialog box location appears to be stored in the profile.  Try changing profiles and see if it reappears.
Big G
« Reply #28 on: December 06, 2005, 07:41:56 AM »
Bob...i tried changing the res of the screens, but the dia didnt appear on the screen.
Shoulda tried changing the profile before i done the reinstall....ive been plagued with error essages ever since.
grrrrr.
M-dub
« Reply #29 on: December 06, 2005, 07:43:47 AM »
So what you're saying is that your avatar bears an uncanny likeness of you?
