Author Topic: Highlighting the line  (Read 4281 times)
paulmcz
« on: November 24, 2005, 08:41:15 PM »
Is there a way that the line selected for this line of code would get highlighted on the screen and stay highlighted?
(setq a (car (entsel "\n Select line: ")))
Thanks, Paul.
LE
Re: Highlighting the line
« Reply #1 on: November 24, 2005, 09:38:16 PM »
Look for the function REDRAW
(redraw a 3)
Andrea
« Reply #2 on: November 24, 2005, 09:43:59 PM »
(vl-cmdf "_select" a "")
(setq b (ssget "_P"))
(sssetfirst nil b)
(alert "line selected")
Keep smile...
LE
« Reply #3 on: November 24, 2005, 10:19:28 PM »
(sssetfirst nil b)
The function redraw is designed for the purpose of highlight an entity, the other form is to use (vlax-highlight obj :vlax-true)
paulmcz
« Reply #4 on: November 24, 2005, 10:35:43 PM »
You guys are the best!
(redraw a 3)
did the trick.
Thanks,
Paul.
paulmcz
« Reply #5 on: November 26, 2005, 01:11:56 PM »
Here is, what I was working on, when I needed the highlighting resolved. For someone who does a lot of converting to polylines and joining, it could come handy as it saves you a few clicks.
Fatty
« Reply #6 on: November 26, 2005, 02:42:53 PM »
Hi Paul
I did try to go another way
Maybe this likes you:
(defun c:tsx (/ a b closed_flag en flag i ss)
  (setq a nil
b nil
  (setvar "pickfirst" 0);to clear previous selset
  (setvar "cmdecho" 0)
    (setq ss (ssget '((0 . "LINE,ARC,LWPOLYLINE")))
  i  -1
       (while (setq en (ssname ss (setq i (1+ i))))
(if (eq (cdr (assoc 0 (entget en))) "LWPOLYLINE")
   (setq flag t)
   nil
(if (= (cdr (assoc 70 (entget en))) 1)
   (setq closed_flag t)
   nil
  (if (not closed_flag)
      (if flag
(command "pedit" ss "j" ss "" "")
(command "pedit" ss "y" "j" ss "" "")
    (alert "\n You can't join anything with closed polyline!")
  (setvar "cmdecho" 1)
  (setvar "pickfirst" 1)
Thank you
Fatty
paulmcz
« Reply #7 on: November 26, 2005, 05:55:08 PM »
Hi Fatty,
Very nice.
One more click saved!
Would you know, how to make it display, "x segments added to polyline", on the command line when the function finishes?
Paul.
« Reply #8 on: November 26, 2005, 06:21:50 PM »
Here's a way to deal with selection sets.
(defun ssredraw ( ss mode / i )
    (if (eq 'pickset (type ss))
        (repeat (setq i (sslength ss))
            (redraw
                (ssname ss (setq i (1- i)))
                mode
;;  hide 'em
(ssredraw ss 2)
;;  show 'em
(ssredraw ss 1)
;;  highlight
(ssredraw ss 3)
;;  unhighlight
(ssredraw ss 4)
paulmcz
« Reply #9 on: November 26, 2005, 09:38:48 PM »
Selection in response to 'ssget' always gets highlited, it's the 'entsel' that for some reason doesn't trigger it. Then, one sometimes needs to deal with it somehow.
This good to know.
Thanks MP.
« Reply #10 on: November 26, 2005, 09:42:05 PM »
Selection in response to 'ssget' always gets highlited ...
Careful Paul, depends on the highlight variable setting --
e.g.
(setvar "highlight" 0)
(ssget)
(setvar "highlight" 1)
(ssget)
paulmcz
« Reply #11 on: November 26, 2005, 09:54:44 PM »
That's true, absolutely!
