Author Topic: Need to lurn..  (Read 6004 times)
Andrea
Need to lurn..
« on: November 23, 2005, 10:08:32 PM »
Hi all..
I have created this simple routine...
Replace word in a layer ;;
By: Andrea Andreetti |;
(defun c:MCR (/ layer_list lfound ltell ls1 lr)
(setq layer_list (ai_table "layer" 4))
(setq lfound (getstring "Mot du calque à changer : ")
      ltell (getstring "Par le mot : "))
(foreach n layer_list
  (setq ls1 (vl-string-search lfound n))
  (if ls1
    (setq lr (vl-string-subst ltell lfound n))
    (vl-cmdf "_.-rename" "_LA" n lr)
But can anyone show me some other way to do similar with VLX or any other mode ?
Just curious to lurn.. :police:
Keep smile...
Re: Need to lurn..
« Reply #1 on: November 23, 2005, 11:42:01 PM »
This will need some work on your part.
Do you know how to determine the Layers Collection.
Do you know how to iterate the collection.
Do you know how to determine the Name and/or Value of an object.
Re: Need to lurn..
« Reply #2 on: November 24, 2005, 02:39:40 AM »
.. but if you want to learn that shouldn't be an issue .. :-)
Adesu
Re: Need to lurn..
« Reply #3 on: November 24, 2005, 03:14:00 AM »
Hi Andrea,how about this
  ;(setq layer_list (ai_table "layer" 4))
  (setq layer_list (table "layer"))
  (setq lfound (getstring "Mot du calque à changer : "))
  (setq ltell (getstring "Par le mot : "))
    (if ls1
(defun table (s / d r)
  (while (setq d (tblnext s (null d)))
    (setq r (cons (cdr (assoc 2 d)) r))
Jürg Menzi
  • Oberegg, Switzerland
Re: Need to lurn..
« Reply #4 on: November 24, 2005, 04:15:48 AM »
In ActiveX:
(defun c:MCR (/ lfound ltell AcaDoc LayCol LayNme LayObj NewNme)
 (setq lfound (getstring "\nMot du calque à changer : ")
       AcaDoc (vla-get-ActiveDocument (vlax-get-acad-object))
       LayCol (vla-get-Layers AcaDoc)
 (vlax-for Obj LayCol
  (setq LayNme (vla-get-Name Obj))
  (if (and
       (not (vl-position (strcase LayNme) '("0" "DEFPOINTS")))
       (vl-string-search lfound LayNme)
;;; Note that the search is case-sensitive, and that vl-string-subst
;;; substitutes only the first occurrence it finds of the string.
   (setq NewNme (vl-string-subst ltell lfound LayNme)
         LayObj Obj
  ((not NewNme)
   (princ "Calque à changer n'existe pas.")
  ((not
    (vl-catch-all-error-p
     (vl-catch-all-apply '(lambda () (vla-Item LayCol NewNme)))
   (princ "Le nouveaux nom du calque déjà existe.")
  (T
   (vla-put-Name LayObj NewNme)
MENZI ENGINEERING GmbH
Re: Need to lurn..
« Reply #5 on: November 24, 2005, 04:23:07 AM »
Andrea wanted to test against bit 4 too Jürg.
;;; (ai_table <table name> <bit> )
;;; Returns a list of items in the specified table.  The bit values have the
;;; following meaning:
;;;  0  List all items in the specified table.
;;;  1  Do not list Layer 0 and Linetype CONTINUOUS.
;;;  2  Do not list anonymous blocks or anonymous groups.
;;;         A check against the 70 flag for the following bit:
;;;                  1  anonymous block/group
;;;  4  Do not list externally dependant items.
;;;         A check against the 70 flag is made for any of the following
;;;         bits, which add up to 48:
;;;                 16  externally dependant
;;;                 32  resolved external or dependant
;;;  8  Do not list Xrefs.
;;;                  4  external reference
;;;  16 Add BYBLOCK and BYLAYER items to list.
Jürg Menzi
Re: Need to lurn..
« Reply #6 on: November 24, 2005, 07:17:10 AM »
AFAIK, there is no property in ActiveX to check for that...
Andrea
Re: Need to lurn..
« Reply #7 on: November 24, 2005, 08:28:11 AM »
hmmm... :? interesting...
But I have found a little problem with this...
in fact if I have a layer named like    M-ALUMINUM-TEXT and need to change M- by E-
This will replace only the first string found in the layer name
like  E-ALUMINUM-TEXT  and not E-ALUMIUE-TEXT
see ?
Keep smile...
Andrea
Re: Need to lurn..
« Reply #8 on: November 24, 2005, 08:59:34 AM »
also..
why this is not working ??
(defun c:MCR ()(/ layer_list lfound ltell ls1 lr)
(setq layer_list (ai_table "layer" 0))
(setq lfound (strcase (getstring "Mot du calque à changer : "))
  (setq ls1 (vl-string-search lfound (strcase n)))
  (if ls1
Keep smile...
Re: Need to lurn..
« Reply #9 on: November 24, 2005, 09:19:19 AM »
What have you done to debug it ?
Jürg Menzi
Re: Need to lurn..
« Reply #10 on: November 24, 2005, 09:58:58 AM »
See comment in my code... For a function that replaces all occurrences of a pattern visit my homepage -> Free Stuff and search for 'VxStringSubst'
Andrea
Re: Need to lurn..
« Reply #11 on: November 24, 2005, 11:17:51 AM »
this....
(defun c:MCR ();;(/ repxok layer_list lfound ltell ls1 lr)
(setvar "CMDECHO" 0)
  (check_repx)
(if repxok
(setq TL (strcase n))
(alert (strcat TL "     " lfound))
  (setq ls1 (vl-string-search lfound TL))
  (if ls1
  (prompt "Calques mis à jour")(princ)
Keep smile...
Andrea
Re: Need to lurn..
« Reply #12 on: November 24, 2005, 11:19:11 AM »
And your website is...!?? :?
Keep smile...
LE
Re: Need to lurn..
« Reply #13 on: November 24, 2005, 11:27:45 AM »
Click in the WWW url link
Re: Need to lurn..
« Reply #14 on: November 24, 2005, 11:28:33 AM »
Or look at his sig.
