Author Topic: Animation  (Read 4486 times)
Amsterdammed
Animation
« on: November 23, 2005, 07:30:46 AM »
Hello everybody,
I’m busy with an animation in a 3d environment in Acad2002. I made a few lisps for the motion and I render the result into bmp files.
Now I want to use the result to show it to co-workers who have no Acad. I did this before in PowerPoint, but it runs slow. I record an 8 frames a sec and PowerPoint takes longer to bring up the dia.
So the question is, does anybody have an idea what program to use for the presentation of bmps in real-time?
Thanks in Advance
Bernd
hendie
Re: Animation
« Reply #1 on: November 23, 2005, 11:19:18 AM »
Paint Shop Pro.. it comes with a free animator program ~ you could even output the bitmaps to avi if you want
Re: Animation
« Reply #2 on: November 23, 2005, 11:39:26 AM »
Ditto what Hendie said, it's a great little proggy.
If you zip up the images so no zip file exceeds 10mb, rename the zip files to piz (e.g. file1.zip.piz) and send them to cadlabs at gmail dot com I'll try to put something together for you tonight.
/offer
Amsterdammed
Re: Animation
« Reply #3 on: November 23, 2005, 12:35:57 PM »
Thanks, Michael,
but i'm not there yet. I just need to make sure i can make little picture show of it before i invest to much time in the lisp for the animation.
Bernd
Fuccaro
Re: Animation
« Reply #4 on: November 28, 2005, 12:07:04 AM »
It must be in BMP format? I would try to convert the images in GIF format and to create an animated gif
Amsterdammed
Re: Animation
« Reply #5 on: November 28, 2005, 09:36:47 AM »
Well,
bmp is what render does.  How would you generate an animated gif?
Bernd
Re: Animation
« Reply #6 on: November 28, 2005, 10:26:17 AM »
Bmps are fine Amsterdammed (as long as you zip em up per my previous message). I can convert to / from just about any common graphics format, including gifs.
David Bethel
Re: Animation
« Reply #7 on: November 28, 2005, 11:51:24 AM »
You might want to try Bink or Smacker
http://www.radgametools.com
I find that they are much faster than Paint Shop Pro.  -David
R12 Dos - A2K
Fuccaro
Re: Animation
« Reply #8 on: November 30, 2005, 12:02:11 AM »
Well,
IRFANVIEW is free for personal use and it will convert images between any formats.
For animated gif images I use a very old program called Microsoft gif animator. You should try a google search for newer tools -for sure you will find dozens of options.
GARILM
Re: Animation
« Reply #9 on: November 30, 2005, 04:31:46 PM »
Hello everybody,
Thanks in Advance
Bernd
I did one a while back using windows movie maker.
It is free and comes with Win XP
Amsterdammed
Re: Animation
« Reply #10 on: December 20, 2005, 11:01:26 AM »
David,
Bink is great. Thanks for the tip and sorry for the late reply, i was out of the game for a while.
Bernd
Didge
Re: Animation
« Reply #11 on: January 04, 2006, 06:30:28 AM »
By way of suggestion,
I would suggest using the "Fast Movie Processor" for compiling the individual frames into an "avi" movie. It's freeware and readily available across the web.
Alternatively you could try my freeware "Ani-Mate" lisp routine, it creates and displays animation sequences from within Acad. I'm half way through updating the code for release 2, unfortunately a change of job and subsequent relocation has put this on hold for a few months.
Download can be found here -->  http://www.caddepot.com/cgi-bin/cfiles/cfiles.cgi?0,0,0,0,26,617
Please note, the email address listed within the software is no longer valid for me.
Think Slow......
