We're trying to scale down a bunch of old files, basically scale down to 50% the titlesheets, the text blocks and the viewports using ),) as the origin, thats the easy part.
We'd also need to change the scale of the viewport to reflect the new scaled down size, thats also fairly easy, the problem is, as you can imagine, that the already scaled down viewport "moved", so the contents of the viewport "shift".
Is there a way to make the contants of the viewports remain anchored relative to the center of the VP, so that when they scale down, and we manually change their scales, the contents remain perfectly aligned as they were originally?
Did I even make sense?
TIA
Hector Rojas
