Author Topic: Revcloud  (Read 3336 times)
hudster
Revcloud
« on: November 17, 2005, 10:02:37 AM »
Does anyone have a copy of a revcloud routine thats written in plain lisp, no vlisp etc?
I need to run this in Intellicad for a few engineers and the ones I have don't do it.
Something with a polyline arc line would ebe good.
Cheers
Andy
Crank
Re: Revcloud
« Reply #1 on: November 17, 2005, 10:19:03 AM »
Don't know about Intellicad, but this is 10 years old, so it might work. :)
Re: Revcloud
« Reply #2 on: November 17, 2005, 01:01:32 PM »
Hudster,
See the version of Pl2Cloud attached to this post, it is an older version of this
http://www.theswamp.org/forum/index.php?topic=1319.0
It doesn't have any vl functions and should work for you.
It uses a DCL file which it creates & slides that need to be placed in the
ACAD search path.
deegeecees
Re: Revcloud
« Reply #3 on: November 17, 2005, 01:04:02 PM »
Hudster,
ACAD search path.
Another quality app from CAB, I use it extensively.
Re: Revcloud
« Reply #4 on: November 17, 2005, 01:10:01 PM »
Thank you sir.
Glad you're getting some good use of it. :-)
deegeecees
Re: Revcloud
« Reply #5 on: November 17, 2005, 01:11:16 PM »
I probably owe you.  :wink:
Murphy
Re: Revcloud
« Reply #6 on: November 17, 2005, 01:39:59 PM »
CAB's revcloud routine is the best thing since the invention of toilet paper!!  :mrgreen:
Re: Revcloud
« Reply #7 on: November 17, 2005, 02:16:34 PM »
.....same for plottabs.
Alright enough of fattening Charle's ego.
YOU  SUCK!! :-P
Just kidding. Keep up the good work  :-)
Ron
hudster
Re: Revcloud
« Reply #8 on: November 18, 2005, 03:46:25 AM »
I found this lisp on the web, it works in IntelliCAD without any DCL files so I'll probably use this.
;|     REVCLOUD.LSP
     Copyright (C) 1997 by Autodesk, Inc.
     Permission to use, copy, modify, and distribute this software
     for any purpose and without fee is hereby granted, provided
     that the above copyright notice appears in all copies and
     that both that copyright notice and the limited warranty and
     restricted rights notice below appear in all supporting
     documentation.
     AUTODESK PROVIDES THIS PROGRAM "AS IS" AND WITH ALL FAULTS.
     AUTODESK SPECIFICALLY DISCLAIMS ANY IMPLIED WARRANTY OF
     MERCHANTABILITY OR FITNESS FOR A PARTICULAR USE.  AUTODESK, INC.
     DOES NOT WARRANT THAT THE OPERATION OF THE PROGRAM WILL BE
     UNINTERRUPTED OR ERROR FREE.
     Use, duplication, or disclosure by the U.S. Government is subject to
     restrictions set forth in FAR 52.227-19 (Commercial Computer
     Software - Restricted Rights) and DFAR 252.227-7013(c)(1)(ii)
     (Rights in Technical Data and Computer Software), as applicable.
     Last revision 10/02/97 Bob Abernethy, dba/CADesigner
     Credits: Original Code, idea and concept by David Harrington
              Bill Kramer, Q.C.
              Phil Kreiker, Q.C.
              Dominic Panholzer, Q.C.
              Randy Kinsley, Error Control
              Greg Robinson
              Bob Abernethy, dba/CADesigner, Added Incremental numbered revision
                                             callout triangle & Layer control
(defun input_integer (a b / c)
   (setq a (strcat a " <"(rtos b 2 0)"> "))
   (setq c (getint a))
   (if (/= c NIL)
      (setq b c)
      (setq b b)
(setq incr 1)
(defun item (ent)
   (cdr(car(entget(ent))))
(defun ERR (s)
  (if (/= s "Function cancelled\n")
    (if (= s "quit / exit abort")
        (alert (strcat "           >> Error << \n"))
  (setvar "CLAYER" CL)
  (setq *error* olderr)
(Defun C:REVCLOUD (/
     ARC_DIST   ;;radius of included arc
     INC_ANGLE  ;;included angle in degrees
     LAST_PT    ;;the last point just entered/shown
     START_PT   ;;where the cloud began
     NEXT_PT    ;;where we are going next
     TMP        ;;tempory holder for radius of bulge
(setq olderr *error* *error* err)
(setq ce (getvar "cmdecho"))
(setq blp (getvar "blipmode"))
(setq osm (getvar "osmode"))
(setvar "cmdecho" 0)
(setvar "blipmode" 0)
(setvar "osmode" 0)
(setq cl (getvar"clayer"))
(if (not (tblsearch "LAYER" "rcloud"))
(command "layer" "m" "rcloud" "c" "2" "rcloud" "")
(command "layer" "s" "rcloud" "")
   ;;--------real program starts here!
   (Setq INC_ANGLE 110)
   (if (and
         (/= ""  (getcfg "AppData/AC_Bonus/Revcld_Bulge"))
         (/= nil (getcfg "AppData/AC_Bonus/Revcld_Bulge"))
     (setq ARC_DIST (atof (getcfg "AppData/AC_Bonus/Revcld_Bulge")))
     (if (= (getvar "DIMSCALE") 0)
       (setq ARC_DIST 0.375)
       (setq ARC_DIST (* 0.375 (getvar "DIMSCALE")))
   );end if
   (prompt (strcat "\nArc length set at " (rtos ARC_DIST 2 3)))
   (setq plwid (getvar"plinewid"))
   (setvar "plinewid" (* (getvar"dimscale")0.0078)); use for wider than zero pline width
;   (setvar"plinewid" 0.0); use for zero pline width
   (setq om (getvar"orthomode"))
   (setvar "orthomode" 0)
   (initget "Arc")
   (setq LAST_PT (GetPoint "\nArc length/<Pick cloud starting point>: "))
   (if (= LAST_PT "Arc")
       (initget 6)
       (setq TMP (getdist (strcat "\nArc length <" (rtos ARC_DIST 2 3) ">: ")))
       (if TMP
         (Progn
           (setq ARC_DIST TMP)
                ;R14 method of saving variable values
           (setcfg "AppData/AC_Bonus/Revcld_Bulge" (rtos ARC_DIST))
       (setq LAST_PT (getpoint "\nPick cloud start point: "))
     ) ;;end STR "RADIUS" test
   (if LAST_PT (progn  ;;start up the cloud generator...
     (setq START_PT LAST_PT
           SAVED_EN (entlast))
     (Prompt "\nGuide crosshairs along cloud path...")
     (Command
        "_.pline"     ;draw cloud as a polyline on current layer
        LAST_PT
        "_a"         ;specify arc option
        "_a"         ;specify angle option
        INC_ANGLE    ;included angle
   )) ;end IF LAST_PT
   (While LAST_PT  ;;as long as we have a last point value,
      (Setq NEXT_PT (GrRead 1)     ;;real time read
            READTYP (car NEXT_PT)
      (if (or (=  5 READTYP) (= READTYP 3)) ;;read a position or a pick?
           (setq NEXT_PT (cadr NEXT_PT))
           (If (or (> (Distance LAST_PT NEXT_PT) ARC_DIST) (= READTYP 3))
             (Progn
               (Command NEXT_PT "_a" INC_ANGLE)
               (Setq LAST_PT NEXT_PT)
           (If (>
               (Distance START_PT NEXT_PT)
             (Progn
               (Command START_PT "_cl")
               (Setq LAST_PT Nil)
               (prompt "\nCloud finished.")
         (prompt "\nMove the pointer to draw the cloud")
      );End if
   );End while
   (setvar "cmdecho" ce)
   (setvar "blipmode" blp)
   (setvar "osmode" osm)
   (setvar "orthomode" om)
   (setvar "plinewid" plwid)
   (Princ)
(Defun c:RCHELP (/)
(prompt "   The Revision Cloud program draws a user specified bulge pline\n")
(prompt "   along the path of the crosshairs. To close the cloud, \n")
(prompt "   simply return to the starting point\n")
(prompt "   The cloud arc length can be specified in the beginning, with keyboard input\n")
(prompt "   by specifying A for Arc, entering a length, or picking two pts.\n")
(textscr)
(Prompt "   REVCLOUD loaded. Type REVCLOUD to draw Revision Cloud,\n")
(prompt "   to close, return to starting point. For additional Help - RCHELP")
(Princ)
