Author Topic: Hot keys  (Read 3424 times)
rugaroo
  • The Other CAD Guy
Hot keys
« on: February 04, 2004, 01:10:38 PM »
Sorry guys, but it's been a while here. Wanted to now for a fact where I could change stuff like hot keys and what not. Also, where do I change what is in my pop-up menu when I click my scrolly thingie? It has been a while, and my mind is just a slush right now.
Thx
R
LDD06-09 | C3D 04-19 | Infraworks 360 | VS2012-VS2017
hyposmurf
Hot keys
« Reply #1 on: February 04, 2004, 01:56:57 PM »
Hot keys,you mean accelarator keys.You'll find them in your acad.mnu theyre right at the end of the file.
Millwork Maker
Hot keys
« Reply #2 on: February 04, 2004, 04:38:06 PM »
Just to clarify a bit more, they can be found just above the tablet configuration if you are editing the 'acad.mns' file.
Steve
Spageddie
Hot keys
« Reply #3 on: February 04, 2004, 10:17:15 PM »
8) If you're refering to keyboard shortcuts......check the acad.pgp file in the support directory
CB_Cal_UK
Hot keys
« Reply #4 on: February 05, 2004, 03:18:28 AM »
Rug,
I think you're looking for the acad.mns file. This is the file which contains the definitions of all the menus and pop ups.
I've customised my snap menus by removing the crap snaps that I don't use and adding my most frequently used 'hard' commands
(ie commands which are buried in long menu chains or which require multiple inputs; for example I have a CPS command which purges the drawing of all objects, audits the drawing, resets the view, zooms all, saves and closes the file)
hyposmurf
Hot keys
« Reply #5 on: February 05, 2004, 07:51:17 AM »
How would you enable a drawing to save and close itself from a menu button?Not heard of CPS before is it scripting?
CB_Cal_UK
Hot keys
« Reply #6 on: February 05, 2004, 08:02:01 AM »
A bit like this . . . . .
***POP0
**SNAP
               [&Object Snap Cursor Menu]
ID_Chris       [->Chris]
ID_Chriszooma    [Zoom All]_'z;a
ID_Chrisdist     [Distance]_di
ID_Chrisdist2    [Distance (Trans)]_'di
ID_Chrisclean    [CAS]_^C^C-Purge;a;;n;audit;y;qsave
ID_Chrisclean    [<-CPS]_^C^C-Purge;a;;n;audit;y;_-view;-top;z;a;qsave;close
ID_ChrisADT    [->ADT Commands]
ID_ChrisJoin     [<-Join Walls]_aecwalljoin
