(defun c:test ()(setqvar1 2var2 "hello"var3 33.4var4 "0"var5 (getvar "clayer"))(resetall))(defun resetall ()(if (= (getvar "clayer") "0")(reset var1 to var5 at 1)))
i'm looking a way to reset some variables...
(setq VarLst '(Var1 Var2 Var3 Var4 Var5))(mapcar '(lambda (l) (set l nil)) VarLst)
Quote from: Andrea on November 16, 2005, 05:05:19 PMi'm looking a way to reset some variables...Something like this?Code: [Select](setq VarLst '(Var1 Var2 Var3 Var4 Var5))(mapcar '(lambda (l) (set l nil)) VarLst)
