Author Topic: ARX Newbie  (Read 4095 times)
deegeecees
ARX Newbie
« on: November 16, 2005, 04:23:49 PM »
What is ARX and how do I get started?
Swift
Re: ARX Newbie
« Reply #1 on: November 16, 2005, 04:33:10 PM »
haha, Here is my best description
ObjectARX is an object oriented c++ Autocad Interface that gives direct access to the drawing database and the AutoCAD application.
You need Autocad, the ARX sdk, and VC++ v6 for Acad 2000-2002 and VC++ v7.0 for ACAD 2004-up and a knowledge of c++
You cannot really substitute compilers. There is a work around or two but they are rather long explanations. You are better off, in my opinion with the correct compiler.
whdjr
Re: ARX Newbie
« Reply #2 on: November 16, 2005, 04:36:10 PM »
What about Visual C++ Express?
  • !false...it's funny 'cause it's true!
Re: ARX Newbie
« Reply #3 on: November 16, 2005, 04:38:51 PM »
Good job Swift, short and sweet!
Basically you get to use the same (or most of the) libraries and enviroment that Autodesk use to create AutoCAD to customise it for your own application.
A programmer's wife tells him, "Run to the store and pick up a loaf of bread. If they have eggs, get a dozen."
The programmer comes home with 12 loaves of bread.
Swift
Re: ARX Newbie
« Reply #4 on: November 16, 2005, 04:40:38 PM »
It may be forceable to work with ACAD 2k (no way with '04 up though, as far as I know) but I haven't tried it.
By default it will not work though.
LE
Re: ARX Newbie
« Reply #5 on: November 16, 2005, 04:47:00 PM »
Also have a look into the ARX tips and tricks from www.manusoft.com about the compilers....
LE
Re: ARX Newbie
« Reply #6 on: November 16, 2005, 04:54:44 PM »
Go to:
arxdummies.blogspot.com
In there you will find the very basics needed.
Good luck.
deegeecees
Re: ARX Newbie
« Reply #7 on: November 16, 2005, 05:57:17 PM »
Thanks everyone!
