Author Topic: sort and loop access table in autocad  (Read 4408 times)
dr-j
« on: November 16, 2005, 05:20:18 AM »
I'm working on a small calculating prog in Autocad.
It should take a record from a access database table, and calculate it.
I already got the calculating part going, but can anyone help me to sort the table according to a certain fieldname.
Also, if i want to loop the caltulation on every record till it finds a correct one, how do i do that?
This is the code that i have:
Public wksObj As Workspace
    Public dbsObj As Database
    Public tblObj As TableDef
    Public fldObj As Field
    Public rstObj As Recordset
Private Sub CommandButton5_Click()
'Berekeningen en toetsen.
Set dbsObj = DBEngine.Workspaces(0).OpenDatabase("D:\My Documents\project\7m535\access database\profielen.mdb")
Set rstObj = dbsObj.OpenRecordset("profielinfo", dbOpenTable)
'Ascending
Dim SQLString As String
SQLString = "profielinfo.* FROM profielinfo ORDER BY profielinfo.profielhoogte ASC;"
so the thing now is that it keeps picking the number 1 id record  instead of the first of the fieldname"profielhoogt" that should have been sorted in ascending order.
if someone can help me on this i'd be very grateful  :-)
Troy Williams
Re: sort and loop access table in autocad
« Reply #1 on: November 16, 2005, 08:24:35 AM »
How about this:
SQLString = "SELECT * FROM profielinfo ORDER BY profielinfo.profielhoogte ASC;"
Swift
« Reply #2 on: November 16, 2005, 08:31:54 AM »
I'm not sure and didn't test this, but try
SQLString = "[b]SELECT * FROM profielinfo[/b] ORDER BY profielinfo.profielhoogte ASC;"
Swift
« Reply #3 on: November 16, 2005, 08:33:08 AM »
good answer Troy  :-o
dr-j
« Reply #4 on: November 16, 2005, 06:12:34 PM »
Thanx a million  :-D
i'll start on it right away and will let you know how it went.
dr-j
« Reply #5 on: November 27, 2005, 05:34:26 PM »
ok i got it workin basically with making the order through vba.
the next thing is I made a query in access as i thought i should have something to compare it with.
but how can you open a query table through vba?
i thought it should be along the line of:
Set rstObj = dbsObj.OpenRecordset("Queryprofielhoogte", dbOpenQuery)
it just gives me a big errorr there so i know i as being a noob must do something terribly wrong.
can someone give me a hand here?
Jim Yadon
« Reply #6 on: December 13, 2005, 03:24:33 PM »
Try this one out...
http://www.w3schools.com/sql/default.asp
I do a fair bit of data crunching and have found SQL to be the smoothest way to handle the selection & transport of data once the connection is established.
