Author Topic: Draw a simple line...  (Read 17799 times)
LE
« on: November 16, 2005, 12:08:40 AM »
Here is a function to draw a simple LINE on model or paper space.
The code does not have any descriptions or comments.
static int ads_myline(void)
struct resbuf *pArgs =acedGetArgs () ;
if( !pArgs ||
pArgs->restype != RTPOINT ||
!pArgs->rbnext ||
pArgs->rbnext->restype != RTPOINT ||
pArgs->rbnext->rbnext )
ads_point& pnt1 = pArgs->resval.rpoint;
AcGePoint3d pntStart( pnt1[X], pnt1[Y], pnt1[Z] );
ads_point& pnt2 = pArgs->rbnext->resval.rpoint;
AcGePoint3d pntEnd( pnt2[X], pnt2[Y], pnt2[Z] );
Usage: (myline (getpoint "\nFrom: ") (getpoint "\nTo: "))
« Last Edit: December 07, 2005, 10:52:13 AM by LE »
LE
Re: Draw a simple line...
« Reply #1 on: November 16, 2005, 12:14:49 AM »
I posted myline function because all the functions or samples on how to draw a line with objectARX on books or in the net [at least by my research], are not complete and do not have the ability to pick the points or to draw the line on paper or model space....
MickD
  • (x-in)->[process]->(y-out)
« Reply #2 on: November 16, 2005, 12:18:45 AM »
So, do you use this in a lisp routine calling 'myline' with some user input from lisp which calls ads_myline passing in the arg's?
I've never looked at ads or linking  with lisp. You would still need your entry point etc yes?
LE
« Reply #3 on: November 16, 2005, 12:23:19 AM »
I am creating my solution using the ARXwizard, by default if you make a function it will place an ads_yourFunctionNameGoesHere.
With the ARXwizard, the code basic or skeleton are generated.... is kind of different as the normal entry point.
« Reply #4 on: November 16, 2005, 12:26:19 AM »
Hi Luis
Just an academic question ..
I've noticed you prefix a lot of your functions with ads_
Is there any special reason you use this prefix ... I usually associate it with Acad prefix for translations of the original Lisp routines into C.
--> Donate to theSwamp<--
LE
« Reply #5 on: November 16, 2005, 12:27:51 AM »
IMPLEMENT_ARX_ENTRYPOINT(CLSP2ARXApp)
ACED_ADSSYMBOL_ENTRY_AUTO(CLSP2ARXApp, myline, false)
« Last Edit: November 16, 2005, 10:04:10 AM by LE »
LE
« Reply #6 on: November 16, 2005, 12:30:05 AM »
Hi Luis
The reason is that I am using the ARXwizard that comes with the ObjectARX SDK.... and by default will add the reserved ads_ prefix.
« Reply #7 on: November 16, 2005, 12:34:16 AM »
Thanks,
I was posting that ques' while you were answering Mick ...
again, purely an academic question ;
Can you change it to something else and still have it work ?
MickD
« Reply #8 on: November 16, 2005, 12:37:25 AM »
Aha! this little macro is where the majic happens -
LE
« Reply #9 on: November 16, 2005, 12:46:05 AM »
Thanks,
Hi Kerry,
I think so, but manually also all the occurrences, I have not done it that way.... the wizard have the ability to make a name change automatically.
LE
« Reply #10 on: November 16, 2005, 12:47:32 AM »
That's the beauty of using the wizard....
[See, ya' tomorrow.... time to zzzZZZ]
deegeecees
« Reply #11 on: November 16, 2005, 11:16:47 AM »
Have a good sleep LE.
So, could someone explain to me the steps involved to make myline work. I ask only that you explain it to me like I'm a fourth grader, as I have never dealt with ARX before, and would like to learn.  :-)
Swift
« Reply #12 on: November 16, 2005, 11:30:12 AM »
I believe that code is the c based ads and not the c++ arx
LE
« Reply #13 on: November 16, 2005, 11:42:18 AM »
It is pure ObjectARX, what happens is that if you use the ARXwizard available from the ARX-SDK installation, that will make the use of the ads_prefix. No relation with the ADS.
I will post the normal alternative and the ADS version, just to notice the difference.
Thanks.
Swift
« Reply #14 on: November 16, 2005, 11:43:35 AM »
I think this will draw a line in arx, I haven't compiled it for a check...
AcDbDatabase *pCurrentDB; // pointer to hole current drawing database
AcGePoint3d stpt(0.0,0.0,0.0); //3d starting point
AcGePoint3d endpt(5.0,5.0,0.0);; //3d ending point
AcDbLine *acLine = new AcDbLine(stpt, endpt); // create a new newline
pCurrentDB = acdbHostApplicationServices()->workingDatabase(); // set pointer to workling database
AcDbBlockTable *pBlockTable;
pCurrentDB->getBlockTable(pBlockTable, AcDb::kForRead); //get the block table
AcDbBlockTableRecord *pBlockTableRecord;
pBlockTable->getAt(ACDB_MODEL_SPACE, pBlockTableRecord, AcDb::kForWrite); // get a blocktablerecord
pBlockTable->close();
AcDbObjectId lineId;
pBlockTableRecord->appendAcDbEntity(lineId, acLine); // Actually adds the line to the drawing
pBlockTableRecord->close();
acLine->close();
