Author Topic: PlotOrigin Toggle  (Read 8268 times)
Dommy2Hotty
PlotOrigin Toggle
« on: November 15, 2005, 10:59:14 AM »
So I'm starting to dabble with VB in AutoCAD.  Managed to modify some code to get the following that will center a layout.  Also made one to set the offset back.  I can't, however, figure out how to make it toggle with one button.  I'm assuming it's the = Not part that I need to modify, but I just don't know how to.  Once again, I'm too busy to read up on it right now, so I would appreciate any suggestions on how to make it toggle, criticism about the layout, or a general explanation about how you're feeling today.  Thank you for your time.  I love you all  :love:
Sub PlotCentered()
    Dim ACADLayout As ACADLayout
    Set ACADLayout = ThisDrawing.ActiveLayout
    ACADLayout.CenterPlot = Not ACADLayout.CenterPlot
    ThisDrawing.Regen acAllViewports
End Sub
Sub PlotOffset()
    Dim newValue(0 To 1) As Double
    newValue(0) = 0
    newValue(1) = 64.516
    ACADLayout.PlotOrigin = newValue
End Sub
deegeecees
Re: PlotOrigin Toggle
« Reply #1 on: November 15, 2005, 11:05:52 AM »
Boolean comes to mind.
How bout an "IF" statement.
Pseudo Code:
If that
Then this
Else this
End If
Bob Wahr
« Reply #2 on: November 15, 2005, 11:10:03 AM »
yeah, that's what I was thinking.  Something like
Sub PlotCenteredOrNot()
    Dim objLayout As ACADLayout
    Set objLayout = ThisDrawing.ActiveLayout
    If objLayout.CenterPlot = False Then
        objLayout.CenterPlot = True
    Else
        newValue(0) = 0
        objLayout.PlotOrigin = newValue
    End If
End Sub
Is that what you're after?
OK, now for the criticism, or at least the critique, okay a well meant pointer.  NEVER EVER FOR ANY REASON EVER should you dim something naming it the same as it's type.  Really, don't.
Arizona
« Reply #3 on: November 15, 2005, 11:20:19 AM »
Bob,
You took the words right out of my mouth. However, Autodesk in their example does exactly the same thing. I was amazed!
Also you are right on with your statements.
Dommy2Hotty
« Reply #4 on: November 15, 2005, 11:26:16 AM »
Thank you very much everyone.  I will test out the new code at lunch time.  And yes, this code was from the help file.  Shame, shame AutoDesk!  :pissed:
Again, I'm JUST getting into this, so bear with me!
Dommy2Hotty
« Reply #5 on: November 15, 2005, 11:36:15 AM »
Error message  :cry:
Bob Wahr
« Reply #6 on: November 15, 2005, 11:41:17 AM »
doh!  Just add "Dim newValue(0 to 1) as double" in your declarations section.
Dommy2Hotty
« Reply #7 on: November 15, 2005, 11:50:55 AM »
SUCCESS!!!   8-)
Thank you everyone!!!
Sub PlotOriginToggle()
    Else
        newValue(0) = 0
    End If
End Sub
deegeecees
« Reply #8 on: November 15, 2005, 11:52:00 AM »
Glad I could help. When you making it out to Frankfort Dom?
Dommy2Hotty
« Reply #9 on: November 15, 2005, 11:58:40 AM »
I was out that way last night.  My girlfriend lives in Mokena.  My ex-girlfriend (before current) lives in Frankfort, and the one before her lives in Mokena...I must like 'em from that area!
deegeecees
« Reply #10 on: November 15, 2005, 12:03:18 PM »
It is kinda backwoods out there, maybe there's something in the water.
Dommy2Hotty
« Reply #11 on: November 15, 2005, 12:10:09 PM »
I know what you mean...
You probably know Morgan's & Thunderbowl...Used to manage the bowling alley and DJ in the bar...
deegeecees
« Reply #12 on: November 15, 2005, 12:16:15 PM »
Very nice pool tables there, good atmosphere, but haven't been there in a couple years. Maybe this W/E get out there and school ya in some pool.
Dommy2Hotty
« Reply #13 on: November 15, 2005, 12:26:01 PM »
That's a possibility...but I must warn you...my dad owns a pool hall in Crestwood...
deegeecees
« Reply #14 on: November 15, 2005, 12:31:35 PM »
Really? A good friend of mine just sold his, "Fast Break" billiards, in Crestwood. Hmmm, interesting.
