Author Topic: LayerStates  (Read 11836 times)
mpeterson79
Re: LayerStates
« Reply #15 on: February 27, 2008, 03:50:15 PM »
We have a LISP routine here that sets up our layers automatically. The problem we have is that the routine essentially errors out if the user has any layers that are frozen or locked.
My thought was to use the code found in this thread to create a temporary layer state, unlock all the layers on, thaw them, then revert to the temporary layer state.
I was able to save, restore & delete the layer state using simple syntax in the LISP routine, but for some reason it invokes the AutoCAD text window when the code is run this way. Here's a sample of the code I was using:
(defun C:MakeLAYER ()
  (setvar "cmdecho" 0)
  (command ".undo" "begin")
  (setq ccl (getvar "clayer"))
(command "-layer" "state" "save" "PreMakelayer" "" "" "")
(command "-layer" "on" "*" "thaw" "*" "unlock" "*" "")
  (setq curlayer "BASEPLATE")
  (command "-layer" "m" curlayer "c" "GREEN" curlayer "")
  (SetLayerDescription curlayer "Baseplate Outline and Mounting Holes")
  (setq curlayer "END")
(command "-layer" "state" "restore" "PreMakelayer" "" "")
(command "-layer" "state" "delete" "PreMakeLayer" "" "")
  (setvar "clayer" ccl)
  (command ".undo" "end")
My problem is this: I'm not sure how to use the code in this thread (though it seems to be what I'm looking for) in order to save a layer state, restore it later on, then delete it.
For example, from the code that CAB last posted, I see this:
(defun save-layerstate (obj name mask)
  (if (vl-catch-all-error-p
 (vl-catch-all-apply
   'vla-save
   (list obj name mask)))
    nil
    T))
So, if I were to want to save a layer state called "PreMakeLayer", what syntax would I use? My assumption was:
(save-layerstate "PreMakeLayer"), but that returns error: too few arguments.
Can someone help a newb along here & clue me in as to how this code is supposed to work? I'd really appreciate it!
Re: LayerStates
« Reply #16 on: February 27, 2008, 03:59:04 PM »
You don't need a layer state.  You just need a lisp that will unlock any locked layers, and return the list of unlocked layers so that you can lock them again after you make your changes.  So something like this should work:
(defun UnlockLayers (Doc / LayList)
    (vlax-for lay (vla-get-Layers Doc)
        (if (equal (vla-get-Lock lay) :vlax-true)
                (setq LayList (cons lay LayList))
                (vla-put-Lock lay :vlax-false)
    LayList
Called like (for the current drawing)
(setq LayList (UnlockLayers (vla-get-ActiveDocument (vlax-get-Acad-Object))))
Then you would do your thing, and after that call the portion below.
(foreach lay LayList
    (vla-put-Lock lay :vlax-true)
Hope that helps.
Re: LayerStates
« Reply #17 on: February 27, 2008, 04:05:10 PM »
What Tim said....you don't need a layerstate. Here is a lisp to unlock and thaw all layers then restore:
;;;to use (unlockthawlayers)
;;; do your stuff
;;;(relockfreezelayers)
(defun unlockthawlayers (/)
  (vlax-map-collection
    (vla-get-layers
    '(lambda (x)
       (cond ((eq (vla-get-lock x) :vlax-true)
      (setq lock (cons x lock))
      (vla-put-lock x :vlax-false)
       (cond ((eq (vla-get-freeze x) :vlax-true)
      (setq freeze (cons x freeze))
      (vla-put-freeze x :vlax-false)
(defun relockfreezelayers (/)
  (if lock
    (mapcar '(lambda (x)
       (vla-put-lock x :vlax-true)
    lock
  (if freeze
       (vl-catch-all-apply 'vla-put-freeze (list x :vlax-true))
    freeze
  (setq lock nil)
  (setq freeze nil)
« Last Edit: February 27, 2008, 04:09:20 PM by ronjonp »
mpeterson79
Re: LayerStates
« Reply #18 on: February 27, 2008, 04:22:10 PM »
Wow, how you guys make this stuff so 'easy' is beyond me. Thanks!
One catch I noticed was that the code I've now asssembled turns all layers on after is has been run. Is there a way to store whether a layer is on or off as well as if it's frozen or locked?
Re: LayerStates
« Reply #19 on: February 27, 2008, 04:28:56 PM »
Are you running (relockfreezelayers) at the end? I cannot duplicate what you are describing.
Ron
mpeterson79
Re: LayerStates
« Reply #20 on: February 27, 2008, 04:36:42 PM »
Yes, I'm running relockthawlayers at the end.
Could it be due to the way I'm creating the layers?
  (setq curlayer "BLDGS FOOTPRINT")
  (command "-layer" "m" curlayer "c" "14" curlayer "")
  (SetLayerDescription curlayer "Footprint on non-test buildings")
SetLayerDescription is the code I got from Peter. I can post that back up if it would help.
Re: LayerStates
« Reply #21 on: February 27, 2008, 04:46:10 PM »
You might have grabbed the code above before I updated it. I had a typo in the lower portion. Copy the code again and let me know if it works.
mpeterson79
Re: LayerStates
« Reply #22 on: February 27, 2008, 04:51:24 PM »
Weird - still does it.
I have three layers I turn off as a test. When I run the code, those three layers turn back on, everytime.  :?
If a layer is off before I run the code, it's on afterwards.
Re: LayerStates
« Reply #23 on: February 27, 2008, 05:01:38 PM »
You can try this then.
(defun UnlockThawOnLayers (Doc / LayList cLayer)
    (setq cLayer (getvar 'CLayer))
        (setq LayList
            (cons
                (cons
                    lay
                    (list
                        (vla-get-LayerOn lay)
                        (vla-get-Freeze lay)
                        (vla-get-Lock lay)
                LayList
        (vla-put-LayerOn lay :vlax-true)
        (if (/= (vla-get-Name lay) cLayer)
            (vla-put-Freeze lay :vlax-false)
    LayList
Do your thing here, then call what is below.
(foreach lst LayList
    (setq tempObj (car lst))
    (vla-put-LayerOn tempObj (cadr lst))
    (vla-put-Lock tempObj (caddr lst))
    (if (/= cLayer (vla-get-Name tempObj))
        (vla-put-Freeze tempObj (cadddr lst))
mpeterson79
Re: LayerStates
« Reply #24 on: February 27, 2008, 05:13:16 PM »
Even with that, it still turns all layers on after executing - I must be using the code incorrectly.
Here's my code currentlY:
; -mlayer.lsp
;Written by Mark Peterson, August 08, 2007
;Revised February 27th, 2008 to include the ability to maintain layer states of drawing
;DESCRIPTION
;This program was written to automate the creation & repair of
;standard layer scheme in AutoCAD
;ERROR HANDLER
(defun err (s)
(if (/= s "Function cancelled")
  (princ (strcat "\nError: " s))
(if ech (setvar "cmdecho" ech))
(setq *error* olderr)
; Written By: Peter Jamtgaard copr 2005
; Set the layer description of a specified layer
; Syntax (setlayerdescription "layername" "layerdescription")
; Function returns T if successful nil if not
(defun SetLayerDescription (strLayer strDescription)
 (if (and (= (type strLayer) 'STR)
  (tblsearch "layer" strLayer)
  (= (type strDescription) 'STR)
   (vla-put-description
(vla-item
(vla-get-layers
strLayer
strDescription
   T
        (setq LayList
            (cons
                (cons
                    lay
                    (list
                        (vla-get-Lock lay)
                LayList
;MAKE LAYER ROUTINE
  (setq curlayer "BLDGS")
  (command "-layer" "m" curlayer "c" "RED" curlayer "")
  (SetLayerDescription curlayer "Non-test Buldings (foam)")
  (setq curlayer "BLDGS DATUM")
  (command "-layer" "m" curlayer "c" "51" curlayer "")
  (SetLayerDescription curlayer "Base elevation datum of non-test buildings")
  (prompt "\nLayer Standards 2007 loaded - type MAKELAYER to begin.")
  (prompt "\n-------------------TEST PHASE--------------------------")
Re: LayerStates
« Reply #25 on: February 27, 2008, 05:14:20 PM »
The only thing I can think of is your code is bonking out before it hits the (relockfreezelayers) :?
Re: LayerStates
« Reply #26 on: February 27, 2008, 05:20:05 PM »
This works for me:
; -mlayer.lsp
;DESCRIPTION
;ERROR HANDLER
(defun err (s)
  (if ech
(vla-item
  (vla-get-layers
  strLayer
strDescription
      T
    (vla-get-layers
    '(lambda (x)
  (if lock
    lock
  (if freeze
    freeze
  (setq lock nil)
  (setq freeze nil)
;MAKE LAYER ROUTINE
  (unlockthawlayers)
    curlayer
    curlayer
(prompt
(prompt
Re: LayerStates
« Reply #27 on: February 27, 2008, 05:21:21 PM »
Agreed.  Maybe you can post the command line prompt from when you call the routine.
Re: LayerStates
« Reply #28 on: February 27, 2008, 05:34:57 PM »
Here's something to look at. Different approach putting layername, color, and description in a list then using a foreach loop:
(defun C:MakeLAYER (/ CCL CLAYER LAYLIST)
  (unlockthawlayers)
  (setq laylist '(("BASEPLATE"
   "GREEN"
  ("BLDGS"
   "RED"
  ("BLDGS DATUM"
   "51"
  (foreach lyr laylist
    (command "-layer" "m" (car lyr) "c" (cadr lyr) (car lyr) "")
    (SetLayerDescription (car lyr) (caddr lyr))
(prompt
(prompt
mpeterson79
Re: LayerStates
« Reply #29 on: February 27, 2008, 05:45:59 PM »
Ronjonp - I'll give your list method a shot next.
Best I can tell, the layers all turning on (unless they were frozen) is a factor of the "-layer" "make" system I was using to create/repair the layers.
From the AutoCAD help menu:
Make
Creates a layer and makes it current. New objects are drawn on the current layer.
Enter name for new layer (becomes the current layer) <current>: Enter a name or press ENTER
If no layer exists for the name you enter, a new layer with that name is created. The new layer is on and assumes the following properties by default: color number 7, the CONTINUOUS linetype, and a lineweight of DEFAULT.
If the layer exists but is turned off, it is turned on.
How it was working for you guys, I have no idea....
