Author Topic: _INSERT VERSUS -INSERT  (Read 1614 times)
SDETERS
« on: November 11, 2005, 11:51:19 AM »
I need to do away with the insert dialog box
What I have is a huge electric symbol library
Every time I try to inset a block from this library the insert dialog box pops up and the block does not insert into the drawing
Please help
Re: _INSERT VERSUS -INSERT
« Reply #1 on: November 11, 2005, 11:58:33 AM »
you must use either (command "insert") or -insert to prevent the dialog from poping up
Bob Wahr
« Reply #2 on: November 11, 2005, 12:00:41 PM »
-insert
or
UNDEFINE INSERT
(defun c:insert()(command "-insert"))
or
(defun c:Ncert()(command "-insert"))
SDETERS
« Reply #3 on: November 11, 2005, 12:17:40 PM »
What I did was replace all of the _insert that was in the menu file to -insert
This worked well
I really dislike that dialog box
Thanks for all the help
Andrea
« Reply #4 on: November 11, 2005, 01:16:52 PM »
Keep smile...
