Author Topic: Adding to this lisp?  (Read 6243 times)
Bob Wahr
Re: Adding to this lisp?
« Reply #15 on: November 10, 2005, 05:39:21 PM »
but since the bars overlap at different places, I wanted to make sure they clear each other.
I haven't made much effort at all at reading the code but are you taking bar sizes into account?
« Reply #16 on: November 10, 2005, 05:43:31 PM »
No Bob, The output is very generic and is indicative only ..
Personally, I'm surprised that an Architect would attempt to represent reo' unrelated to the actual requirements. ..
Bob Wahr
« Reply #17 on: November 10, 2005, 06:03:16 PM »
How do you make sure the bars clear each other or anything else without taking bar diameters into account?  For that matter, how do you generic something like this?  Spacing differring....grah
If it makes him happy good enough.
pmvliet
« Reply #18 on: November 10, 2005, 06:48:27 PM »
clearances for rebar in concrete does vary. Say your concrete is exposed to earth, you need more clearance because the earth will deteriorate the concrete at a faster rate then say air. Granted, this is over an extended time periord but it must be accounted for in the design.
my $.02
Pieter
vinnyg
« Reply #19 on: November 11, 2005, 09:11:25 AM »
Thanks to Jeff and Cab for their input, help and direction. I can learn a lot from
these guys!
Maybe they ought to be teaching lisp??
Thanks again,
vinnyg
« Reply #20 on: November 11, 2005, 09:14:56 AM »
But ... they are, real time.
But I know what you mean => more formally, like classes. I agree.
Sdoman
« Reply #21 on: November 12, 2005, 08:46:13 AM »
On the bar that has
Pages: [1] | Go Up                         Reply | Notify of replies | Mark unread | Print
below the last post, click reply.  On that page, click "Additional options"  You should see the attachment bit.
Thanks for the tip Bob.  I thought it wasn't possible to attach files at this forum until I read your post.     (I guess I should explore more)
Bob Wahr
« Reply #22 on: November 14, 2005, 01:45:17 PM »
There are some areas, Lagniappe for example, that don't allow attachments.
