Author Topic: 'start_list' not working...Please help!  (Read 11268 times)
Re: 'start_list' not working...Please help!
« Reply #15 on: November 08, 2005, 04:11:04 PM »
Excellent.
Does it display the dialog per the start_dialog call (inside the and structure; inside the *dialog* function)?
cadanalyst@gmail.com • http://cadanalyst.slack.com • http://linkedin.com/in/cadanalyst
whdjr
« Reply #16 on: November 08, 2005, 04:27:17 PM »
Yes.
whdjr
« Reply #17 on: November 08, 2005, 04:29:44 PM »
oops...no it does not.  It loads the dialog and flashes the dialog when the 'new_dialog' call is made, but the start_list nils out before the dialog is filled.
« Reply #18 on: November 08, 2005, 04:38:04 PM »
Well ... my suggestion is o put this little snip (progn (alert "I'm here") t) within the and structure --
(and
    (setq id (load_dcl "att.DCL"))
    (start_list "atts")
    (mapcar 'add_list lst)
    (not (end_list))
    (action_tile "cancel" "(done_dialog 0)")
And keep moving it ahead, line by line until it stops displaying the alert.
whdjr
« Reply #19 on: November 08, 2005, 04:45:41 PM »
(and
    (start_list "atts")
    (not (end_list))
That was the last place it worked.
« Reply #20 on: November 08, 2005, 05:01:29 PM »
You are not specifying your dialog box to use ... you MUST also use NEW_DIALOG to invoke the dialog to use.
Use this scenario:
(new_dialog "attribute_edit" id)
whdjr
« Reply #21 on: November 08, 2005, 05:08:21 PM »
I already call 'new_dialog' here:
(defun load_dcl (name / dcl dcl_id)
    (while
      (if (minusp (setq dcl_id (load_dialog name)))
(setq dcl (getfiled "Select correct DCL file location: "
    dcl
    "dcl"
    (+ 8 128)
(not (new_dialog "attribute_edit" dcl_id))
    dcl_id
But I changed it and put it like this:
    (while
    dcl
    "dcl"
    (+ 8 128)
;(not (new_dialog "attribute_edit" dcl_id))
    dcl_id
<snippet>
(start_list "atts")
<snippet>
But it still doesn't work. :-(
« Reply #22 on: November 08, 2005, 05:23:20 PM »
Will,
The Code you posted loads and displays without exception for me. Tested with AC2005 winXPpro.
whdjr
« Reply #23 on: November 08, 2005, 05:25:09 PM »
Yeah it worked for me this morning, but now it doesn't.  I don't know what changed to make it not work.
« Reply #24 on: November 08, 2005, 05:30:33 PM »
Have you tried a System wide search for ANY file modified date stamped today. See if anything seems out of place ...
whdjr
« Reply #25 on: November 08, 2005, 05:34:04 PM »
I only worked on one other lisp file today and it didn't have anything to do with a dcl file.  I did not do a system wide scan though.
Well guys I appreciate your help today and look for some more tomorrow.  Right now I have to leave.  Maybe things will look brighter in the morning. :-)
« Reply #26 on: November 08, 2005, 05:38:11 PM »
Does this anomaly ONLY apply to this routine, or to ALL your DCL's ?
added :
Just for completeness, loaded and ran in AC2006 as well as 2005.
« Last Edit: November 08, 2005, 05:56:50 PM by Kerry Brown »
« Reply #27 on: November 08, 2005, 06:33:15 PM »
I won't be able to look at this until 10pm tonight, but I certainly will try after that.
Hope this gets solved soon (my money is still on start_list, add_list etc. being redefined).
« Reply #28 on: November 08, 2005, 06:49:22 PM »
Wouldn't something like this verify that?
_$ (type start_list)
SUBR
_$ (setq tmp start_list)
#<SUBR @0243c7e8 START_LIST>
_$ (setq start_list nil)
nil
nil
_$ (setq start_list 7)
7
INT
_$ (setq start_list tmp)
« Reply #29 on: November 08, 2005, 06:51:59 PM »
(type start_list) => SUBR
(defun start_list () (princ))
