Author Topic: run a lisp in dwgs WITHOUT opening the dwgs?  (Read 19532 times)
Amsterdammed
« on: November 03, 2005, 07:48:54 AM »
Hello,
I just ran the “Layer filter delete.lsp” from the post down here on this page and saw a dwg with the size of 2 MB limited to 400KB. So that is great.
 Now I wonder:
We gave a lot of dwgs on our server, a lot of 3rd party dwgs with 20000+ layer filters, too.
Is there a way to approach the dwgs and run the “layer filter delete” WITHOUT opening the dwgs? (I know how to do it in a script with opening one for one).
Thanks in advance,
Bernd
Re: run a lisp in dwgs WITHOUT opening the dwgs?
« Reply #1 on: November 03, 2005, 08:15:01 AM »
you might be able to do it using ObjectDBX by importing the type libraries into vlisp
whdjr
« Reply #2 on: November 03, 2005, 09:10:59 AM »
Here is one I put together for AutoCad 2000:
(defun LayerFiltersDelete (doc)
  (vl-Catch-All-Apply
    '(lambda ()
       (vla-Remove
(vla-GetExtensionDictionary
   (vla-Get-Layers doc)
"ACAD_LAYERFILTERS"
(defun w:*error* (msg)
  (princ "\nError: ")
  (princ msg)
  (if (and dbxdoc (not (vlax-object-released-p dbxdoc)))
    (vlax-release-object dbxdoc)
  (gc)
(defun get_dwgs (path)
  (mapcar '(lambda (x)
     (mapcar '(lambda (y)
(strcat x "\\" y)
     (vl-directory-files x "*.dwg" 1)
  path
(defun c:lfd_odbx (/ kword folder file files dbxdoc of *error*)
  (initget 1 "Yes No")
  (setq kword (getkword
  "Do you want to search in subdirectories? [Yes/No]: "
files (cond ((eq kword "Yes")
       (apply 'append
      (get_dwgs (*list_folders* (acet-ui-pickdir)))
      ((eq kword "No")
       (setq file (getfiled "Select a File" "" "dwg" (+ 4 128)))
       (car (get_dwgs (list (vl-filename-directory file))))
*error* w:*error*
  (if (not (*DBX-Register*))
    (*error* "Could not load the ObjectDBX Interface.")
  (setq dbxdoc (vla-GetInterfaceObject
(vlax-get-acad-object)
"ObjectDBX.AxDbDocument"
  (foreach f files
    (setq of (vl-catch-all-apply
       '(lambda ()
  (vlax-invoke-method dbxdoc 'open f)
    (if (vl-catch-all-error-p of)
      (*error* (vl-catch-all-error-message of))
(LayerFiltersDelete dbxdoc)
(princ
  (strcat "\nDeleting Layer Filters in " f)
(vla-saveas dbxdoc f)
  (gc)
Amsterdammed
« Reply #3 on: November 03, 2005, 09:18:27 AM »
Will,
I miss something in your code:
; error: no function definition: *LIST_FOLDERS*
Bernd
whdjr
« Reply #4 on: November 03, 2005, 09:30:37 AM »
oops...sorry  :oops:
Your actually missing some more too.
Just use this instead of what I posted earlier:
;;;Utilities to register ObjectDBX with AutoCAD 2K
(defun *DLLRegister* (dll)
  (startapp "regsvr32.exe" (strcat "/s \"" dll "\""))
(defun *ProgID->ClassID* (ProgID)
  (vl-registry-read
    (strcat "HKEY_CLASSES_ROOT\\" progid "\\CLSID")
(defun *DBX-Register* (/ classname server)
  (setq classname "ObjectDBX.AxDbDocument")
    ((*ProgID->ClassID* classname))
    ((and
       (setq server (findfile "AxDb15.dll"))
       (*DLLRegister* server)
    ((not (setq server (findfile "AxDb15.dll")))
     (alert
       "Error: Cannot locate ObjectDBX Type Library (AxDb15.dll)..."
    (T
     (*DLLRegister* classname)
     (or
       (alert
    "Error: Failed to register ObjectDBX ActiveX services..."
(defun *layout_list* (/ lst)
  (vlax-map-collection
    (vla-get-layouts
    '(lambda (x) (setq lst (cons x lst)))
  (cdr
    (*sort* lst 'vla-get-taborder)
(defun *sort* (lst func)
  (vl-sort lst
      '(lambda (e1 e2)
         (< ((eval func) e1) ((eval func) e2))
  (vl-Catch-All-Apply
    '(lambda ()
       (vla-Remove
    "ACAD_LAYERFILTERS"
  (princ "\nError: ")
  (princ msg)
  (gc)
         (strcat x "\\" y)
     path
             (apply 'append
            ((eq kword "No")
   *error*   w:*error*
  (foreach f files
          '(lambda   ()
   (princ
  (gc)
Amsterdammed
« Reply #5 on: November 03, 2005, 09:51:13 AM »
Will,
indeed there were more missing.
But........... Sitll missing the *LIST_FOLDERS* function
Bernd
« Reply #6 on: November 03, 2005, 10:04:31 AM »
I get the same error as well Will.
When in doubt....search the forum :).
http://www.theswamp.org/forum/index.php?topic=3564.msg43226#msg43226
« Last Edit: November 03, 2005, 10:08:55 AM by ronjonp »
« Reply #7 on: November 03, 2005, 10:09:45 AM »
Quote from: Amsterdammed
Hello,
Now I wonder:
Thanks in advance,
Bernd
Please be careful Amsterdammed, I've seen attempts at automatic fixes become automatic fubars. Backup your data, do exhaustive tests on representative sample data, have a recovery plan. You don't want to be the latest entry in this thread.
« Reply #8 on: November 03, 2005, 10:28:48 AM »
Will,
So what the next step in troubleshooting when I get the error:
Error: Could not load the ObjectDBX Interface.
Error: Automation Error. Problem in loading application
I changed the AxDb15.dll to AxDb16.dll since I'm on 2005.
So I did some searching in the registry and found that "ObjectDBX.AxDbDocument" is "ObjectDBX.AxDbDocument.16". Changed that but still getting the error:
Thanks,
Ron
« Last Edit: November 03, 2005, 10:47:01 AM by ronjonp »
Amsterdammed
« Reply #9 on: November 03, 2005, 10:30:12 AM »
Right Micheael,
It still always scares me when a  lot of things are  done automatically. But we have everything on tape  as back up, and I sure will not let a lisp run all over the server to change  all the dwgs. But I will definitely use it for cleaning up 3rd party dwgs we use as xrefs.
But thanks for the reminder Michael, indeed I don’t want to join the “wound liking dogs” club.
Bernd
whdjr
« Reply #10 on: November 03, 2005, 11:01:36 AM »
Sorry for the confusion guys:
This should work for 2000 and 2002:
  (vl-registry-read
    ((and
     (alert
    (T
     (or
       (alert
    (vla-get-layouts
  (cdr
  (vl-sort lst
   '(lambda (e1 e2)
(defun *list_folders* (path)
  (defun get_folders (folder / f)
       (cons (setq f (strcat folder "\\" x))
     (apply 'append (get_folders f))
    (cddr (vl-directory-files folder nil -1))
  (cons path (apply 'append (get_folders path)))
  (vl-Catch-All-Apply
    '(lambda ()
       (vla-Remove
"AcLyDictionary"
  (princ "\nError: ")
  (princ msg)
  (gc)
(strcat x "\\" y)
  path
(defun c:lfd_odbx (/ kword folder file files dbxdoc of *error* lst)
       (apply 'append
      ((eq kword "No")
*error* w:*error*
  (foreach f files
       '(lambda ()
      (setq lst (cons (vl-catch-all-error-message of) lst))
(princ
  (gc)
  (if lst (princ lst))
This should work for 2004:
    (vla-get-layouts
  (cdr
  (vl-sort lst
   '(lambda (e1 e2)
  (vl-Catch-All-Apply
    '(lambda ()
       (vla-Remove
"AcLyDictionary"
  (princ "\nError: ")
  (princ msg)
  (gc)
(strcat x "\\" y)
  path
       (apply 'append
      ((eq kword "No")
*error* w:*error*
"ObjectDBX.AxDbDocument.15"
  (foreach f files
       '(lambda ()
(princ
  (gc)
This should work 2005 and 2006:
    (vla-get-layouts
  (cdr
  (vl-sort lst
   '(lambda (e1 e2)
  (vl-Catch-All-Apply
    '(lambda ()
       (vla-Remove
"ACAD_LAYERFILTERS"
  (princ "\nError: ")
  (princ msg)
  (gc)
(strcat x "\\" y)
  path
       (apply 'append
      ((eq kword "No")
*error* w:*error*
  (foreach f files
       '(lambda ()
(princ
  (gc)
edit:  Added functionality to print a list of drawings that were not changed.
« Last Edit: November 03, 2005, 01:42:45 PM by whdjr »
« Reply #11 on: November 03, 2005, 12:33:39 PM »
Thanks will :).
One more question....how would one go about modifying this so it ignores readonly files rather than crashing the proggie?
« Last Edit: November 03, 2005, 12:38:12 PM by ronjonp »
« Reply #12 on: November 03, 2005, 12:42:37 PM »
Note that the use of ObjectDBX and saving the drawing loses the Drawing preview image. If you wish to maintain the image, see THIS post that uses a helper app. If you need help implementing it just let me know.
ronjonp, you will need to wrap the Saveas line into a vl-catch-all-apply function. I would suggest placing the name of any file that cannot be saved into a text file so you know which ones were not modified.
whdjr
« Reply #13 on: November 03, 2005, 01:10:51 PM »
Thanks will :).
I'll have to check into that.  I came across that before but I don't remember what I did to resolve it.
whdjr
« Reply #14 on: November 03, 2005, 01:12:52 PM »
...ronjonp, you will need to wrap the Saveas line into a vl-catch-all-apply function. I would suggest placing the name of any file that cannot be saved into a text file so you know which ones were not modified.
I think it is already done that way Jeff.
       '(lambda ()
