Author Topic: run a lisp in dwgs WITHOUT opening the dwgs?  (Read 19507 times)
Re: run a lisp in dwgs WITHOUT opening the dwgs?
« Reply #30 on: November 03, 2005, 06:19:40 PM »
'm not sure which answer makes more sense...the contrived one by Dr.Wahr or the real one. :)
One guess..... 25
« Reply #31 on: November 03, 2005, 06:22:29 PM »
I liked his explaination also. :lol:
Close. 28 now.
deegeecees
« Reply #32 on: November 04, 2005, 05:27:28 PM »
Not to get off topic but, is it possible to plot with ObjectDBX?
« Reply #33 on: November 04, 2005, 05:42:47 PM »
No.
But I would really like to be proven wrong ...
« Reply #34 on: November 04, 2005, 06:05:49 PM »
Quote from: Kerry Brown
I know I can't do it for the subject at hand.... :|
but give me a while and  I'm sure I will find something you did wrong .....  :laugh:
Bob Wahr
« Reply #35 on: November 04, 2005, 06:11:01 PM »
don't remember for sure but it seems like open drawing alliance or whatever they call themselves these days had something that could at least in theory allow plotting without opening Autocad.
whdjr
« Reply #36 on: November 05, 2005, 01:48:44 PM »
No.
I had a conversation from Autodesk once and they said you can only print using ObjectDBX if you sign up as an ObjectDBX Developer with Autodesk.
« Reply #37 on: November 05, 2005, 02:22:11 PM »
Ch'Ching, $5000 entry fee (now called Real Dawg).
Dinosaur
« Reply #38 on: November 05, 2005, 03:13:33 PM »
I have downloaded the Open Design Alliance (formerly OpenDWG.org) toolkit for r2005.  I haven't done anything with it but if someone can point me in a direction I will try to find out if it has anything to help.
