Author Topic: error: null interface pointer ..  (Read 19001 times)
Sdoman
Re: error: null interface pointer ..
« Reply #15 on: November 02, 2005, 11:00:42 PM »
This exact situation is one of the reasons why I attempt to use unique names for any global variables I use.
All it takes is for code in a VLX or FAS that the user has no control over to use code as demonstrated with the same variable names as you and the whole lot falls down.
Agreed.  That's why I try to use unique names.  You never now when some (bozo) user might run some poorly written code that he/she downloaded from some forum some where. :)
LE
« Reply #16 on: November 02, 2005, 11:02:34 PM »
How about using a protected namespace VLX.... there we don't have any problema.
« Reply #17 on: November 02, 2005, 11:03:45 PM »
There is only few cases when a release is needed on visual lisp code.
Agreed Luis. When referencing objects other than from the AutoCAD Object Model primarily.
« Reply #18 on: November 02, 2005, 11:04:06 PM »
Yep, like when you use vla-GetInterfaceObject, vlax-get-object, vlax-create-object ...
(ot: good idea to obscure your team support control).
<nodding.gif>
« Reply #19 on: November 02, 2005, 11:04:45 PM »
Yep, just need to make sure the correct Document is referenced :)
Yes, I noticed that too
« Reply #20 on: November 02, 2005, 11:05:13 PM »
Cool timing.
 :kewl:
Sdoman
« Reply #21 on: November 02, 2005, 11:07:56 PM »
I never learned how to do the protected namespace thing.  But it's time I learned.  What's the best way to get started?  I read the help files and they just made my eyes glaze over.
LE
« Reply #22 on: November 02, 2005, 11:13:16 PM »
<nodding.gif>
Did not want it to show my bad manners....  :kewl:
LE
« Reply #23 on: November 02, 2005, 11:15:08 PM »
If you need help on that... let me know Steve.
I got the impression that ALL the help stuff from adesk was very clear......   :evil: [ahaaaaa]
Sdoman
« Reply #24 on: November 02, 2005, 11:19:07 PM »
HELP!
LE
« Reply #25 on: November 02, 2005, 11:24:24 PM »
Don't know if can be good idea to post code about that here... or it will be better to send you a code sample via PM... or.....
« Reply #26 on: November 02, 2005, 11:26:51 PM »
Perhaps use a new topic in   Show your stuff Luis.
That way access is restricted to logged in members.
« Reply #27 on: November 02, 2005, 11:28:16 PM »
As far as release is concerned, is it only when you create an object or also when you do this?
(setq obj (vlax-ename->vla-object ename))that you need to release the object.
I gather that this code need no release?
Sdoman
« Reply #28 on: November 02, 2005, 11:28:27 PM »
Luis,
Thanks for the help.  Maybe we should start a new topic.  I'm sure others would be interested in knowing how to make protected name space files.
« Reply #29 on: November 02, 2005, 11:28:54 PM »
BTW. Thanks for the input guys. This turned into a really interesting thread.
