Quote from: Bob Wahr on November 02, 2005, 03:07:55 PMis it pronounced whidjer or wahidjer?Ummm yes, I'd like to buy a vowel please.
...I found long ago that testing for the availability of a property via vlax-property-available-p, testing its current state, and then changing the state was far slower than just putting the hammer down inside a error trap. Not recommended as a blanket technique, but for some things it dramatically drops prosessing times where applicable and beneficial (like processing tens of thousands of drawings via objectdbx). Use carefully, again, not a blanket solution....
So...Do you always advocate speed over safety?
I don't do letters. I'm going to pronounce it as something. If you won't give your preferance, I get to choose. As of now, you are Whidjer.
Quote from: whdjr on November 02, 2005, 03:46:52 PMSo...Do you always advocate speed over safety?I believe I addressed that already.
Just out of curiosity, can any other this be used when you come across a block that cannot be exploded? Not talking 2k6, but lower versions. There have been times when you have a block that is not exploded because of different x,y scales and other things of that nature.
