Author Topic: getpoint <hopped-up>  (Read 12311 times)
Re: getpoint <hopped-up>
« Reply #15 on: October 31, 2005, 05:52:16 PM »
Shoot, I just worked this out.
  (setq promptmessage "Select a point"
        default '(0.0 0.0 0.0))
  ;(initget InitBit InitString)
(setq
  returnvalue (if basepoint
                (vl-catch-all-apply 'getpoint (list promptmessage basepoint))
                (vl-catch-all-apply 'getpoint (list promptmessage))
  ((vl-catch-all-error-p returnvalue)
   nil
  (returnvalue)
  (t
   default
« Reply #16 on: October 31, 2005, 05:53:22 PM »
Real close Alan, I believe if the user hit escape you'd want to gracefully exit. It's the right ide, you just need an exit condition for the loop.
(defun c:test ( / message point )
    ;;  as long as the user picks points and doesn't
    ;;  press escape stay keep prompting for points ...
    (setq message "Select a point: ")
    (while
        (and
            (null
                    (vl-catch-all-apply
                       '(lambda ( )
                            (setq point
                                (getpoint message)
            point
        ;;  stay the course
    (princ "Done.")
« Reply #17 on: October 31, 2005, 05:55:08 PM »
Like this Michael ? <snip>
Ermmm, yeah, that.
« Reply #18 on: October 31, 2005, 06:01:48 PM »
I think the speed is pretty irrelevant in a case like this, unless (unlikely) one were going to validate points in the thousands. But to play along --
Further to this point. I am curbing any obsessive inclination I had to wring the last clock click out of procedures.
My priority has shifted to maintainability as a primary .. something to do with my deteriorating memory cells perhaps.
« Reply #19 on: October 31, 2005, 06:03:49 PM »
<nodding.gif> Diminishing returns et. al. </nodding.gif>
« Reply #20 on: October 31, 2005, 06:15:56 PM »
Did i misunderstand your reply?
That will exit on anything but an error.
« Reply #21 on: October 31, 2005, 06:25:36 PM »
Nope ; There's a null in there applied to the return
So the good nil is changed to .. (and ( T .....
Determines whether an argument is an error object returned from vl-catch-all-apply
(vl-catch-all-error-p arg)
Arguments : arg
Any argument.
Return Values
T, if the supplied argument is an error object returned from vl-catch-all-apply; otherwise nil
« Reply #22 on: October 31, 2005, 06:28:14 PM »
Sorry Alan, my mistake. I didn't realize you wanted to eliminate the user's ability to escape out of the loop. I had wrongly applied the rationale that if the user hit escape we should gracefully exit, and while that seems a good idea to me, that isn't what you coded for. Somehow I didn't see your preface text or comment. Duh. I'm blaming it on last night's lousy sleep, which, Scout's honour is true, but also completely LAME.
 :whistle:
« Reply #23 on: October 31, 2005, 06:30:22 PM »
 :oops:   Oooops .. Me too
« Reply #24 on: October 31, 2005, 06:34:27 PM »
OK, How about this?
  (while
    (and
      ;(not (initget initbit initstring))
        (setq returnvalue (if basepoint
      (or
        (initget "Yes No")
        (/= (vl-catch-all-apply
              'getkword
              (list "Are you sure you want to abort?[Yes/No] <No>")
            "Yes"
        (exit)
  (if returnvalue
    returnvalue
    default
« Reply #25 on: October 31, 2005, 06:37:56 PM »
Thats pretty close Alan
This scares me a little :
(exit)
This whole topic is really interesting to me ..
« Last Edit: October 31, 2005, 06:46:11 PM by Kerry Brown »
« Reply #26 on: October 31, 2005, 06:44:15 PM »
I supose the question needs to be raised.
What is the users expectation for termination of a routine ?
Should we discourage bashing the ESC key ?
Should we provide a "Quit" keyword ...
.. I think the decision to terminate operation should be made in the main code body .. so we perhaps just pass back a Symbol to reflect the users option .. ?
« Reply #27 on: October 31, 2005, 07:09:08 PM »
Included only for ideas ... I wrote this long ago, like < 1999, and abused it by adding escape code (should be completely rewritten but other stuff demands attention). Anyway, run and and observe the behavior if you wish, this is how I'd expect a function to behave when hitting escape.
(defun GetPoints ( / GetPointAux i point result cancelled )
    (defun GetPointAux ( from message / result )
        (setq cancelled ;; note, local global
                (vl-catch-all-apply
                   '(lambda ( )
                        (initget 32)
                        (setq result
                            (if from
                                (getpoint from message)
                                (getpoint message)
        result
        (   (car
                (setq result
                    (list
                        (GetPointAux
                            nil
                            "\nPick start point: "
            (while
                (setq point
                    (GetPointAux
                        (car result)
                        "Next point: "
                (grdraw point
                    (cadr
                        (setq result
                            (cons point result)
                    -7
            (setq i 0)
            (while (< i (1- (length result)))
                (grdraw
                    (nth i result)
                    (nth (setq i (1+ i)) result)
                    -7
            (if (null cancelled) ;; the local global
                (reverse result)
« Reply #28 on: October 31, 2005, 07:14:30 PM »
So, perhaps you need to pass an Exit flag
 Allow Escape
 Prompt for Escape
 Return a flag to calling routine on escape
 Return nil on Escape
 No Escape allowed
Oops, MP snuck in there.
« Reply #29 on: October 31, 2005, 07:54:36 PM »
........    What happens if the user enters an invalid point like
8 <enter>
I'vecome back to this ...
8 <enter> could be considered valid because of
the AutoCAD direct distance entry mechanism.
ie : return a point 8 units in the direction of the cursor
You were trying to trick me Alan, yes ?
