Author Topic: getpoint <hopped-up>  (Read 12318 times)
0 Members and 3 Guests are viewing this topic.
« on: October 31, 2005, 01:39:20 AM »
This was prompted by a thread elsewhere on the forum.
Would anyone like to try to break this. ESC does not count.
I won't comment on or explain the code just yet.
A good exercise for anyone learning VLisp would be to disect the code and write some documentation.
Please post documentation seperate from the body of code.
Note the Menu option when Right Clicking when the command is active when prompting for Pt4 {keywords option}.
Here is a couple of test statements.
(setq Pt1 (kb:getpoint nil nil nil nil nil)
      Pt2 (kb:getpoint "NextPoint" '(10 10 10) (+ 1 8) nil nil)
      Pt3 (kb:getpoint "Specify WorkPoint"
                       '(0 0 0)
                       (+ 1 32)
                       '("BasePoint" "Apex")
                       Pt1
      Pt4 (kb:getpoint "Specify Another Point"
                       Pt3
                       (+ 1 8 32)
                       '(0 0 0)
This is the main routine and a helper :
;| #lib.
kb:getpoint (Promptmsg Default InitBit KeyList BasePoint ...
Revised Library : kwb 20051031
(defun kb:getpoint (Promptmsg                               ; The prompt string.
                    Default                                 ; Value to return if response is <enter>
                    InitBit                                 ; Initget bit
                    KeyList                                 ; Initget keywords List of strings
                    BasePoint                               ; Base point < or nil >
                    /              PromptMessage  InitString
                    KeyWordString  ReturnValue
  (setq PromptMessage (strcat "\n"
                              (cond (Promptmsg)
                                    ("Specify Point")
  (if KeyList
    (setq InitString    (substr
                          (apply
                            'strcat
                            (mapcar '(lambda (item) (strcat " " item)) KeyList)
                          2
          KeyWordString (vl-string-translate " " "/" InitString)
    ;; else,
    (setq InitString "")
  (or InitBit (setq InitBit 0))
  (setq PromptMessage
         (strcat
           PromptMessage
           (if KeyWordString
             (strcat PromptMessage " [" KeyWordString "]")
           (if Default
             (progn (setq InitBit (logand InitBit (~ 1)))
                    (if (= (type Default) 'str)
                      (strcat " <<" Default ">>")
                      ;; else, assume it is a point .. user beware
                      (strcat " <<" (kb:ptos Default nil nil) ">>")
  (initget InitBit InitString)
  (if (setq ReturnValue (if BasePoint
                          (getpoint PromptMessage BasePoint)
                          (getpoint PromptMessage)
    ReturnValue
    Default
;| #lib.
kb:ptos (pt xmode xprec
Revised Library kwb 20021103
Arguments :
pt       : point list
xmode    : Units to use , can be nil
xprec    : display precision to use , can be nil
Return : A point formatted as a string
(defun kb:ptos (pt xmode xprec)
  (or xmode (setq xmode (getvar "LUNITS")))
  (or xprec (setq xprec (getvar "LUPREC")))
  (if pt
    (strcat (rtos (car pt) xmode xprec)
            (rtos (cadr pt) xmode xprec)
            (rtos (caddr pt) xmode xprec)
« Last Edit: October 31, 2005, 01:42:40 AM by Kerry Brown »
Re: getpoint <hopped-up>
« Reply #1 on: October 31, 2005, 03:17:08 PM »
Kerry,
I would like to check it out but work calls.
Maybe tonight.
What happens if the user enters an invalid point like
8 <enter>
« Reply #2 on: October 31, 2005, 03:31:30 PM »
Ditto what Alan said, I've some thoughts on boolean short circuiting etc.
« Reply #3 on: October 31, 2005, 03:59:56 PM »
Alan, yes It's a problem
There are a few things I'm not too happy about.
The changing initBIT when a default is provided
Trapping for ESC
I'd be interested in hearing those thoughts Michael ..
« Reply #4 on: October 31, 2005, 05:06:13 PM »
Incorporating something like this may help, I think :
(defun validPoint-p (TestPoint)
  (not (vl-catch-all-error-p (vl-catch-all-apply 'vlax-3d-point TestPoint)))
(validPoint-p '(1 1 1))                           ; => T
(validPoint-p '(1 1))                             ; => T
(validPoint-p nil)                                ; => nil
(validPoint-p 2)                                  ; => nil
(validPoint-p (mapcar '+ '(1 1 1) '(2 2 0)))      ; => T
« Reply #5 on: October 31, 2005, 05:19:04 PM »
Interesting ....
(defun validPoint-px (TestPoint)
  (and (listp TestPoint)
       (eq 3 (length TestPoint))
       (vl-every 'numberp TestPoint)
Benchmarking [M.P. 2005] .................Elapsed milliseconds for 16384 iteration(s)/ relative Timing :
    (VALIDPOINT-P (QUOTE (1 1 1)))......2283 / 1.3646 <slowest>
    (VALIDPOINT-PX (QUOTE (1 1 1))).....1673 / 1.0000 <fastest>
« Reply #6 on: October 31, 2005, 05:22:32 PM »
I think the speed is pretty irrelevant in a case like this, unless (unlikely) one were going to validate points in the thousands. But to play along --
(defun IsPoint ( point )
    (and
        (listp point)
        (< 1 (length point) 4)
        (vl-every 'numberp point)
« Reply #7 on: October 31, 2005, 05:26:34 PM »
Also, it might be interesting to test the performance (just for gits and shiggles) with invalid data.
« Reply #8 on: October 31, 2005, 05:28:05 PM »
Speed : Agreed,
(< 1 (length point) 4)  :VS:  (eq 3 (length Point))
yeah, I noticed this potential in the other thread, but didn't want to spoil the ambience :)
« Reply #9 on: October 31, 2005, 05:29:54 PM »
Then I am chagrined for having mentioned it sir.
:oops:
« Reply #10 on: October 31, 2005, 05:32:51 PM »
Kerry on the escape prevention, perhaps
  ;;  prevent the user from escaping
  (setq msg "Select a point")
  (while
      (setq pt (vl-catch-all-apply 'getpoint (list msg)))
« Reply #11 on: October 31, 2005, 05:37:14 PM »
Real close Alan, I believe if the user hit escape you'd want to gracefully exit. It's the right ide, you just need an exit condition for the loop.
« Reply #12 on: October 31, 2005, 05:40:36 PM »
.. chagrined for having mentioned it sir.
:oops:
no hassles, silly  :)
« Reply #13 on: October 31, 2005, 05:42:58 PM »
Like this Michael ?
(BenchMark '((validPoint-p '(1 1 1))
             (validPoint-px '(1 1 1))
             (validPoint-p '(x y z))
             (validPoint-px '(x y z))
             (validPoint-p nil)
             (validPoint-px nil)
    (VALIDPOINT-P (QUOTE (X Y Z)))......2304 / 1.5759 <slowest>
    (VALIDPOINT-P (QUOTE (1 1 1)))......2223 / 1.5205
    (VALIDPOINT-P nil)..................2183 / 1.4932
    (VALIDPOINT-PX (QUOTE (1 1 1))).....1602 / 1.0958
    (VALIDPOINT-PX (QUOTE (X Y Z))).....1602 / 1.0958
    (VALIDPOINT-PX nil).................1462 / 1.0000 <fastest>
; 1 form loaded from #<editor "K:/FunStuff/Swamp/getpoint-003.LSP">
« Reply #14 on: October 31, 2005, 05:46:53 PM »
  (while
I was looking at something like this :
  (setq parameterList (if BasePoint
                        (list PromptMessage BasePoint)
                        (list PromptMessage)
        ReturnValue   (vl-catch-all-apply 'getpoint parameterList)
  (if (vl-catch-all-error-p ReturnValue)
    (progn (setq ReturnValue nil)
           (alert "\nESC was pressed. \nBut tell someone who cares \n< replace with suitable message > ...")
    (if ReturnValue
      ReturnValue
      Default
