Author Topic: Trimming selection set  (Read 7324 times)
hmspe
« on: October 29, 2005, 02:05:34 AM »
I'm working on a generalized routine to automatically trim arcs drawn between symbols in electrical drawings.  The issue is that arc and circle components in the symbol block should be used as edges to trim to, but line and lwpolyline components should not.  I found code that explodes the symbol then gets all intersection points using:
    (setq 8list (vlax-invoke 8symbobj 'Explode))
    (foreach 8obj 8list
      (if (setq 8intpts (MyErrorCheck
                         'vlax-invoke
                         (list 8obj 'IntersectWith 8arcobj acExtendNone)
        (progn        ....
8symbobj is the symbol block and 8arcobj is the intersecting arc.  A dump of 8list for a fluorescent strip block returns:
(#<VLA-OBJECT IAcadLine 033d8a24> #<VLA-OBJECT IAcadLine 033dd4a4> #<VLA-OBJECT
IAcadLine 033dd444> #<VLA-OBJECT IAcadCircle 033db304>)
I need to remove all the IAcadLine entities from 8list before calling the foreach loop.  I'm just getting started with the vl-/vla- end of lisp and don't have a clue how to do this.  Any guidance would be appreciated.
Martin
"Science is the belief in the ignorance of experts." - Richard Feynman
Re: Trimming selection set
« Reply #1 on: October 29, 2005, 07:49:49 AM »
<coded blind>
If 8list needs to have a copy of every entity that results from exploding 8symbobj then this --
(setq filtered8list
    (vl-remove-if-not
       '(lambda (object)
            (member
                (vla-get-objectname object)
               '("AcDbArc" "AcDbCircle")
        8list
Otherwise this should suffice --
(setq 8list
    (vl-remove-if-not
       '(lambda (object)
            (member
        (vlax-invoke
            8symbobj
           'Explode
Warning -- I'm on my first coffee.
« Reply #2 on: October 29, 2005, 07:57:53 AM »
Ack, should have had the entire first cup before responding.
I had assumed because of your 'dump' text that (vlax-invoke 8symbobj 'Explode) was returning a list, it doesn't, it returns a variant array. Hang on a second ..
« Reply #3 on: October 29, 2005, 08:04:07 AM »
Talking to myself ...
DUH ME, just noticed you're employing vlax-invoke, rather than vlax-invoke-method. In that case it will return a list rather than a variant array, and my first post should work.
All I ask is that all the beans that gave up their life for my coffee today have the highest amount of caffeine, is that too much too ask?
 :roll:
Fatty
« Reply #4 on: October 29, 2005, 08:36:36 AM »
 :roll:
Hi MP
Sorry I don't know your real name...
I think better yet you will drink beer instead coffee...
This likes me more:
(vl-member-if (function (lambda (x)
  (wcmatch (vla-get-objectname x)
  "AcDbArc,AcDbCircle")))
  (vlax-invoke (vlax-ename->vla-object (car (entsel))) 'Explode))
Regards,
Fatty
« Reply #5 on: October 29, 2005, 08:47:19 AM »
Michael's the name, insomnia's the game.
Yeah, that would work too.
Cats, and the many ways to skin 'em.
REOW!
Fatty
« Reply #6 on: October 29, 2005, 09:05:39 AM »
REOW!
Michael, thanks
They are say in Russia no difference: across or along
Oleg
« Reply #7 on: October 29, 2005, 09:12:07 AM »
Glad to make your acquaintance sir Oleg.
Fatty
« Reply #8 on: October 29, 2005, 11:15:24 AM »
If I will be speak frankly, then I surmised, who you there is personally,
but I not was confident accurately of that.
Now I can say that you are an idol #1 for me and many other users
I do not know the reasons, which forced you not to appear at other forum (discussion.group) but this there is a large loss for them...
I remove my hat into the sign of respect for you
(Sorry for my bear English)
Fatty
« Reply #9 on: October 29, 2005, 11:24:47 AM »
Whoa!
I don't deserve this praise, but I'm going to cherish it no less!
Thank you sir, you didn't need to say that -- you are obviously a man of great generousity, nothwithstanding your ability to quickly disect a problem and formulate an efficient and elegant solution.
Post.BookMarkNow ;
 :-o
Fatty
« Reply #10 on: October 29, 2005, 11:46:40 AM »
Whoa!
Post.BookMarkNow ;
 :-o
I'm simple ex-worker and I know only simple words
I said only truth and nothing besides the truth...
I will memorize this day
Thanks Michael
hmspe
« Reply #11 on: October 29, 2005, 12:10:34 PM »
Thanks, guys.
Martin
« Reply #12 on: October 29, 2005, 01:21:15 PM »
As will I, be assured! Thank you Oleg.
Fatty
« Reply #13 on: October 29, 2005, 01:57:59 PM »
Such difficult talking pulls my thick skin therefore today I will
make an escape from here
Regards
Oleg
hyposmurf
« Reply #14 on: October 29, 2005, 02:16:14 PM »
Fatty
I'd second that, you come up with some great code, strive to help other members so much with their requests and at the same time its all done in a polite manner, makes you one cool bloke.
