Author Topic: xref control  (Read 12304 times)
Bob Wahr
Re: xref control
« Reply #15 on: November 01, 2005, 12:40:18 PM »
Well, considering that it works the same in 2006 as 2004, it will be one of these three
Quote from: Autodesk
Blah blah known issue blah future release blah blah.
Blah blah blah desired behavior.
or
whdjr
Re: xref control
« Reply #16 on: November 01, 2005, 02:15:10 PM »
Ok, here's your scenario:  Xref 'A' into 'B'.  Xref 'B' into 'C'.  Then when you don't want to see 'A' you just unload 'A' in 'C'.
Here is a workaround (although cumbersome):  Xref 'A' into 'B' and 'B' into 'C'.  When you don't want 'A' in 'C' open 'B' and change xreftype (just double-click type in the xref manager)  to "overlay' for 'A'.  Then save 'B' and reload 'B' in 'C'.
Easy right?  Not really but it is a workaround.
Hope this helps,
Bob Wahr
Re: xref control
« Reply #17 on: November 01, 2005, 02:40:07 PM »
can you change the xreftype of a nested xref?  I'm thinking not.
whdjr
Re: xref control
« Reply #18 on: November 01, 2005, 02:54:07 PM »
You change the xreftype in 'B' (hence the reason I said cumbersome).
I didn't say it was a good or better way just another way.
Bob Wahr
Re: xref control
« Reply #19 on: November 01, 2005, 02:56:05 PM »
true dat.
