Author Topic: Help with error  (Read 2827 times)
Scott
Help with error
« on: January 31, 2004, 11:48:26 AM »
Can someone please tell me what this is?
Regenerating model.
Initializing....
.Done.
Command:
Command:
Command:
AutoCAD Express Tools Copyright ゥ 2000 Autodesk, Inc.
_.-VBARUN
Command: Initializing VBA System...
Macro name: ドライブ名:\・・・\SUFAC_Free.dvb!ThisDrawing.pusubMakeMenu
Macro not found.
This shows up in the command line when starting Map 5.  I'm assuming most of this is normal, however, the last part about a macro not being found is confusing me.  Is this normal, and if not, how do I delete the command that is calling for the macro that can't be found?
Thanks in advance
Scott
Help with error
« Reply #1 on: January 31, 2004, 12:46:27 PM »
Do you have a custom menu?
Are you using a thrid party add-on?
Open up the acad.mnl file in notepad and look for something that resembles that last line. Some for the acadmap.mnl file.
Keith
Help with error
« Reply #2 on: January 31, 2004, 09:21:41 PM »
Macro not found.
You will notice that the path for the dvb file is something that could not possibly exist on an english windows installation, unless it was a corrupted path.
So, I suspect that at some point the program that is calling the VBARUN command, is corrupted or was written in a non english language.
First do a search on your computer for the file SUFAC_Free.dvb If it exists the path to where it is IS the correct one that should be in the Macro name: line.
I would suggest looking in the following locations for any occurence of VBARUN and see what program is loading it.
ACAD.LSP
ACADDOC.LSP
ACAD2000DOC.LSP
STARTUP SUITE
EMBEDED MACROS
