Author Topic: Question 37  (Read 8948 times)
Question 37
« on: October 25, 2005, 04:29:29 PM »
Question for the LISPERS.
Suppose you needed to pen a couple padding functions that take a string and right or left pad it with n specified characters.
You might code it like this (naming after antiquated basic equivalents):
RSET:
(defun rset ( text padding maxlen )
    (substr
        (   (lambda ( )
                (while
                        (strlen (setq padding (strcat padding padding)))
                        maxlen
                (setq text (strcat padding text))
        (- (strlen text) (1- maxlen))
Example:
(rset "text" " " 10)
==> "      text"
LSET:
(defun lset ( text padding maxlen )
    (substr
        (   (lambda ( )
                (while
                        maxlen
                (strcat text padding)
        1
        maxlen
Example:
(lset "text" " " 10)
==> "text      "
Then you notice there is duplicated logic, so you distil the functions by writing an auxiliary function:
SETAUX:
(defun setaux ( padding maxlen )
    (while
            maxlen
    padding
RSET:
    (substr
        (setq text
            (strcat
                (setaux padding maxlen)
                text
LSET:
    (substr
        (strcat text (setaux padding maxlen))
        1
        maxlen
You're thinking it looks pretty good but then you realize, at least theoretically, that it demonstrates poor coding practice.
What poor coding practice do the rewritten functions demonstrate?
What would that practice be called?
On the other hand you realize they also demonstrate good coding practice.
What good coding practice do the rewritten functions demonstrate?
Kerry, please hold off responding to this one, at least for a bit.
« Last Edit: October 25, 2005, 05:00:06 PM by MP »
Re: Question 37
« Reply #1 on: October 25, 2005, 05:07:12 PM »
Time to exercise the wetware < the stuff between the ears>
whdjr
Re: Question 37
« Reply #2 on: October 26, 2005, 10:11:33 AM »
Quote from: MP
Answer:  Haven't figured this one out yet.  Maybe doing more than one thing in a function.
Quote from: MP
Answer:  You have one function doing one thing.
Re: Question 37
« Reply #3 on: October 26, 2005, 10:43:42 AM »
Hint: the word 'padding'
Chuck Gabriel
Re: Question 37
« Reply #4 on: October 26, 2005, 11:26:45 AM »
I would say that it is good that you used named abstractions and bad that the names chosen aren't particulary expressive.
Some people would say that it is bad that your functions have side effects (i.e. they modify their arguments).
whdjr
Re: Question 37
« Reply #5 on: October 26, 2005, 01:50:44 PM »
I did think it was kind of odd how 'lset' added characters to the right side and 'rset' added characters to the left side. :-o :|
It must be a Canadian thing! :lol:
Re: Question 37
« Reply #6 on: October 26, 2005, 01:57:07 PM »
Perhaps the vb/vba help was authored by a canuck!
Nudge: Read up on lset/rest vb/vba functions.
Re: Question 37
« Reply #7 on: October 26, 2005, 01:58:09 PM »
Agree on both counts, particularly the latter.
Re: Question 37
« Reply #8 on: October 26, 2005, 01:59:13 PM »
Usually that's a very good thing in my book.
Why might it not be?
Re: Question 37
« Reply #9 on: October 26, 2005, 02:13:01 PM »
passing an abundance of variables back and forwards can be unkind to your performance.
It's interesting that the OOP concepts of abstraction and obfuscation have snuck in.
Re: Question 37
« Reply #10 on: October 26, 2005, 02:18:06 PM »
... and while not generally a lisper's concern, if considering software architecture as a science -- what about cohesion / coupling issues?
LE
Re: Question 37
« Reply #11 on: October 26, 2005, 05:37:47 PM »
As I mentioned, I am not a programmer....
But I would use for the auxiliary function something like this:
(defun setaux  (padding maxlen / str)
  (setq str "")
  (repeat maxlen (setq str (strcat str padding)))
  str)
And now that heard today about turbo pascal - not here.... here is a translation of ins v1.5 (insert)
(defun ins  (src tgt inx)
  (if (/= inx 0)
    (strcat (substr tgt 1 (1- inx)) src (substr tgt inx))
    (eval tgt)))
(defun ins_str (src tgt inx)
  (if (/= inx 0)
    (eval tgt)))
(defun pos_str (subcad cad / cnt)
  (setq cnt 1)
  (while
    (and (/= subcad (substr cad cnt (strlen subcad)))
(< cnt (strlen cad)))
     (setq cnt (1+ cnt)))
  (if (= subcad (substr cad cnt (strlen subcad)))
    (eval cnt)
    (eval 0)))
And the answer is................................................ ?
LE
Re: Question 37
« Reply #12 on: October 26, 2005, 05:40:47 PM »
and also would avoid the re-write of var "text"
    (substr
        (setq text
            (strcat
                text
I never had changed the value of an argument on my functions.... as far I remember....
Chuck Gabriel
Re: Question 37
« Reply #13 on: October 26, 2005, 05:46:23 PM »
I try to avoid it in lisp programs, but there was a time when I considered anything fair game as long as it got the job done.
However, it is a very common paradigm in some languages, particularly VB(A).  As long as it is clearly documented, I don't see a problem with it.
Re: Question 37
« Reply #14 on: October 26, 2005, 05:50:33 PM »
Luis this may lose something in translation ..
I was raised on a farm. One of our neighbours was an Irishman who has a good turn of phrase < and a lovely daughter >.
2 of his expressions have stayed in my menory.
I was always in a hurry, and he'd say to me "Take your hurry, boy."
The other expression is fairly common.
"Boy, If it quacks like a duck, chances are it waddles"  taken by me to mean that things are what they are, irrespective of what we call them.
Perhaps you mean you are not formally trained. .. I'm not, and few of us are.
QUACK.
« Last Edit: October 26, 2005, 05:53:56 PM by Kerry Brown »
