Author Topic: Open Source Survey Package?  (Read 18759 times)
Re: Open Source Survey Package?
« Reply #45 on: October 24, 2005, 11:37:20 PM »
If anyone wants a C++ compiler ... here.
Resources for same.
« Last Edit: October 24, 2005, 11:40:31 PM by MP »
« Reply #46 on: October 25, 2005, 07:26:17 AM »
Can that version compile the ObjectARX stuff?
« Reply #47 on: October 25, 2005, 07:36:47 AM »
Doubtful, ObjectARX tends to be compiler and version centric. But it could be used to develop the core dlls, which (as I understood it) are slotted to be standard (non activex) windows dlls.
Swift
« Reply #48 on: October 25, 2005, 08:10:11 AM »
Amazingly it can be made to compile for ACAD 2000(normally requires VC++ 6) if you know what other packages to download from Microsoft. However, the additional packages needed to make it compile for ACAD 2004+(VS.net 2002) are not available.
Swift
« Reply #49 on: October 25, 2005, 08:11:35 AM »
Not set in stone yet.
« Reply #50 on: October 25, 2005, 08:17:31 AM »
Is the project going to include both intellicad and autocad? Is that "set in stone"?
« Reply #51 on: October 25, 2005, 08:17:48 AM »
Very true, a premature assumption. Picking the compiler before establishing the overall architecture is folly. I was literally just saying, If anyone wants a c++ compiler ...
« Reply #52 on: October 25, 2005, 08:25:58 AM »
MP makes a really good point, and I'll go one further. I think somebody has to take on the role of coordinator, one person who knows what is already done, what needs to be done, and who is working on what.
I nominate Swift.
Agreed, a project like this needs a coodinator, a lead.
Swift, if I second the nomination will you accept?
« Reply #53 on: October 25, 2005, 08:36:53 AM »
Do we think a project this size (It has the potential to be big) should be run by several?
Create the overall specs and seperate into groups with a proj lead in each.
« Reply #54 on: October 25, 2005, 08:41:21 AM »
I agree their needs to be a spec (that's an absolute) and there has to be a delegation tree / resposibility matrix. It's simple divide and conquer with accountability.
« Reply #55 on: October 25, 2005, 08:44:01 AM »
IMO you still need one person in charge of the whole shabang.
« Reply #56 on: October 25, 2005, 08:47:04 AM »
Agreed. Swift has two nominations.
« Reply #57 on: October 25, 2005, 08:48:14 AM »
Well I'm out-a-here, talk to you folks in a couple hours if I can.
Swift
« Reply #58 on: October 25, 2005, 09:02:51 AM »
It doesn't have to be. It might be easier if we concentrated on Autocad now and bring Intellicad in later or vise-versa.
Swift
« Reply #59 on: October 25, 2005, 09:06:58 AM »
Alright, I'll do it.
