Author Topic: String Counting  (Read 2921 times)
hudster
String Counting
« on: October 22, 2005, 04:15:01 AM »
How can I count the number of characters in a string, entered using "getstring",  and then delete the same number of characters from the end of another string.
Re: String Counting
« Reply #1 on: October 22, 2005, 06:03:47 AM »
(defun c:test ()
  (setq originalString "Something like this perhaps would work.")
  (setq StringLength (strlen (setq tmp (getstring "Enter a string : "))))
  (setq newString (substr originalString
                          1
                          (- (strlen originalString) StringLength)
Re: String Counting
« Reply #2 on: October 22, 2005, 06:08:54 AM »
If you cant work out what's happening in that routine, just yell ...
Fatty
Re: String Counting
« Reply #3 on: October 22, 2005, 06:23:07 AM »
Hi Hudster
This one is very quick and dirty but it seems like work for me
Please spell my stupid prompts
Thank you
F.
(defun cut-tail (/ elist en ent new_str patt strng typ)
  (setq patt (getstring T "\nType pattern to cut :\n"))
  (setq ent (entsel "\nSelect text to cut the tail : "))
  (while (not (wcmatch (setq typ (cdr (assoc 0 (entget (car ent)))))
       "TEXT,MTEXT"))
    (princ "\nPlease select text or mtext!")
  (setq en    (car ent)
elist (entget en))
  (setq strng (cdr (assoc 1 elist)))
  (if (eq typ "MTEXT")
      (setq new_str (substr (cdr (assoc 1 (entget (car ent))))
    1
    (- (strlen strng) (strlen patt) (strlen "\\P"))))
      (setq elist (subst (cons 1 new_str) (assoc 1 elist) elist))
      (entmod elist)
      (entupd en))
    1
    (- (strlen strng) (strlen patt))))
      (entmod elist)
      (entupd en)
;CaLL: (cut-tail)
