Author Topic: Using C# to Open and Close Drawing Files  (Read 15640 times)
HD
« on: October 18, 2005, 09:41:42 AM »
Hello All,
At the moment, I am simply trying to open and close drawings. The following C# program opens each drawing that was selected from a dialog box. I am not sure how to close each selected drawing (without saving changes) after it has been opened. I found the "Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.CloseAndDiscard()" method, but I am not sure how to make it work.
using System;
using System.Windows.Forms;
namespace TitleBlockConvert
   /// <summary>
   /// Summary description for Class1.
   /// </summary>
   public class Class1
      public Class1()
         // TODO: Add constructor logic here
      // Define command.
      [CommandMethod("TBCONV")]
      static public void TBCONV()
         // Get drawings to process
         Autodesk.AutoCAD.Windows.OpenFileDialog dwgsForm =
            new Autodesk.AutoCAD.Windows.OpenFileDialog("Drawings to Process","","dwg","",
            Autodesk.AutoCAD.Windows.OpenFileDialog.OpenFileDialogFlags.AllowMultiple);
         if (dwgsForm.ShowDialog() != DialogResult.OK)
            return;
         string[] dwgfiles = dwgsForm.GetFilenames();
         for (int i = 0; i < dwgfiles.GetLength(0); i++)
            AcadApp.DocumentManager.Open(dwgfiles,false);
            // Stuff to do...
Draftek
Re: Using C# to Open and Close Drawing Files
« Reply #1 on: October 18, 2005, 10:03:38 AM »
Try this:
Document oDoc = AcadApp.DocumentManager.Open(dwgfiles,false);
// do your stuff
oDoc.CloseAndDiscard();
Draftek
« Reply #2 on: October 18, 2005, 10:06:03 AM »
If your going to batch drawings, you might also make sure your command is defined in the application env, not the drawing by using the CommandFlags.Session attribute.
