This is worse that pulling teeth ..
Unless you say otherwise :
Text will be used .. Mtext will be converted.
Style will be "oxford standard" [ currently defined using romand.shx ]
Width scale factor will be changed from 0.75 to 1.0
0.18 High Text will be changed to 0.2 High and the insert point moved Y -0.2
Table label Text will be changed to uppercase.
Can you resolve these. .. may need to email the .shx files
Substituting [isocp.shx] for [Babtie].
Substituting [isocp.shx] for [Mark 1].
mapping.shx required
civil.shx required
