Methinks I need to explain what I have to do on a regular basis.
I have a sheet of over 100 cross sections dumped from MX. They spit them out in one big block, but to get them to look right in the drawing frame each has to be a certain distance from the edge of the other, we usually get 12 to a drawing frame.
Currently I select a section, pick and endpoint, then pick snap from, then pick another endpoint and type the required distance it is needed to be away from the last section (if you understand what I'm trying to say, or is a diagram needed?)
Many thanks
T
