Author Topic: dwgprops !?  (Read 4134 times)
Andrea
dwgprops !?
« on: October 13, 2005, 01:27:55 PM »
Hi all,
How can I get DWGPROPS in lisp ?
Keep smile...
Re: dwgprops !?
« Reply #1 on: October 13, 2005, 01:32:56 PM »
Use the SummaryInfo object.
Andrea
Re: dwgprops !?
« Reply #2 on: October 13, 2005, 01:35:33 PM »
heu ?
Keep smile...
Re: dwgprops !?
« Reply #3 on: October 13, 2005, 01:40:43 PM »
huh?
(vlax-dump-object
    (vla-get-summaryinfo
        (vla-get-activedocument
            (vlax-get-acad-object)
    t
Spewage:
; IAcadSummaryInfo: IAcadSummaryInfo Interface
; Property values:
;   Author = ""
;   Comments = ""
;   HyperlinkBase = ""
;   Keywords = ""
;   LastSavedBy = ""
;   RevisionNumber = ""
;   Subject = ""
;   Title = ""
; Methods supported:
;   AddCustomInfo (2)
;   GetCustomByIndex (3)
;   GetCustomByKey (2)
;   NumCustomInfo ()
;   RemoveCustomByIndex (1)
;   RemoveCustomByKey (1)
;   SetCustomByIndex (3)
;   SetCustomByKey (2)
Andrea
Re: dwgprops !?
« Reply #4 on: October 13, 2005, 02:02:44 PM »
Thanks MP...
but i'm not very familer to VLAX..
I need to keep the item 2...
Keep smile...
Re: dwgprops !?
« Reply #5 on: October 13, 2005, 03:33:54 PM »
This will retrieve all the custom info per the original order --
(defun foo ( )
    (   (lambda ( summaryinfo / i result name value )
            (repeat (setq i (vla-numcustominfo summaryinfo))
                (setq result
                    (cons
                            (vla-getcustombyindex
                                summaryinfo
                                (setq i (1- i))
                               'name
                               'value
                            (cons name value)
                        result
Example:
(foo)
    ("myname1" . "myvalue1")
    ("myname2" . "myvalue2")
    ("myname3" . "myvalue3")
Note that due to Autodesk's poor implementation of this if you place information in said object, you will not be able to read it back until the drawing is saved, closed and re-opened. Thank Autodesk.
« Last Edit: October 13, 2005, 04:24:54 PM by MP »
Andrea
Re: dwgprops !?
« Reply #6 on: October 13, 2005, 03:53:15 PM »
MP ...
you a genious !
I have to learn more about VLAX..
thanks.
Keep smile...
Re: dwgprops !?
« Reply #7 on: October 13, 2005, 04:05:23 PM »
I wish. Thank you Andrea.
Andrea
Re: dwgprops !?
« Reply #8 on: October 14, 2005, 10:42:03 AM »
a little more question..
I do I change a value ? or add one ?
Keep smile...
Re: dwgprops !?
« Reply #9 on: October 14, 2005, 12:07:32 PM »
Found this in my "junk" file.
;Document.SummaryInfo
(defun get-suminfo-obj ()
  (vla-get-SummaryInfo
(vla-get-ActiveDocument
(defun login-as-author ()
  (vlax-put-property
    (get-suminfo-obj)
    'Author
    (getvar 'loginname)
