Author Topic: length of a 3dpoly  (Read 5391 times)
Amsterdammed
length of a 3dpoly
« on: October 10, 2005, 10:41:32 AM »
Hello there,
Who can i get the length of a 3dpoly?
Thanks, Bernd
Re: length of a 3dpoly
« Reply #1 on: October 10, 2005, 10:45:52 AM »
Forgive me, but did you look at the length property?
« Reply #2 on: October 10, 2005, 11:12:44 AM »
Something like this?
(if (setq ent (car (entsel)))
    (setq obj (vlax-ename->vla-object ent))
    (if (vlax-property-available-p obj 'Length)
      (print (strcat (rtos (vlax-get-property obj 'Length)) " = Length"))
« Reply #3 on: October 10, 2005, 11:29:51 AM »
That would work. :)
So many ways to skin the cat (Tracey made me say it). Here's a very simple variant ...
(defun c:SumLengths ( / getlen ss i result )
    (defun getlen ( ename / result )
        (vl-catch-all-apply
           '(lambda ( )
                (setq result
                    (vla-get-length
                        (vlax-ename->vla-object ename)
        (if result result 0.0)
    (if (setq result 0.0 ss (ssget))
        (repeat (setq i (sslength ss))
            (setq result
                    (getlen (ssname ss (setq i (1- i))))
                    result
    result
You can go a lot deeper with the vlax-curve-* functions as has been demonstrated elsewhere on le swamp.
LE
« Reply #4 on: October 10, 2005, 11:35:17 AM »
Command: lengthen
Select an object or [DElta/Percent/Total/DYnamic]:
Current length: 7.9172
jonesy
  • SuperMod
« Reply #5 on: October 10, 2005, 11:39:11 AM »
That would work. :)
Did not ^-^ :angel:
t-bear
« Reply #6 on: October 10, 2005, 12:13:56 PM »
I like that LE ... sticking with the programs basic functions for the solution......... Saves writing a bunch of silly code thingies.  :ugly:(although that IS what this forum is all about, right?  Writing silly little code thingies?  The kind T-Bear can't live without?)......... :angel: :lmao:
Amsterdammed
« Reply #7 on: October 11, 2005, 03:17:02 AM »
Michael,
I was already out of office when you posted
Yes I tought the ‘Length property must do it.
But when I run
  (vlax-get-property (vlax-ename->vla-object (entlast)) 'Length)
I get
  ActiveX Server returned the error: unknown name: LENGTH
Although when I inspect the
I get in the inspect window
(wanted to paste in here)
i get
  Acad3Dpolyline
in the header
If i do the same with a normal line, i get the length property.
That was when I posted it to the swamp.
Marks post gives nil as a result and yours 0.0
I use Acad 2002, but that should not be it.
Thanks in advance
Bernd
Amsterdammed
« Reply #8 on: October 11, 2005, 03:23:45 AM »
Of course Luis approach works, but i need the length in a calculation, not on the printscreen.
« Reply #9 on: October 11, 2005, 03:58:52 AM »
The vla-curve stuff is available with AC2002
So ... try something like this perhaps
(if (and (setq obj (vlax-ename->vla-object (car (entsel))))
         (= (vla-get-objectname obj) "AcDb3dPolyline")
  (setq len (vlax-curve-getdistatparam obj (vlax-curve-getendparam obj)))
« Reply #10 on: October 11, 2005, 04:02:45 AM »
You think ??
Yes it could .. The Length Property became available for stuff other than lines in AC2004.
Have a look at the properties of a 3DPline in the Object Model Diagram ..
[added]
.. and just goes to show that it helps to mention which version of Autocad we are using ...
« Last Edit: October 11, 2005, 04:07:35 AM by Kerry Brown »
« Reply #11 on: October 11, 2005, 04:18:32 AM »
should have mentioned ..
If you change the ObjectName test to suit, this should work for
Polylines, 3DPolylines, Splines, Lines, Arcs, Circles and Ellipses
Amsterdammed
« Reply #12 on: October 11, 2005, 05:42:23 AM »
Thanks Kerry
Right in all cases.
Your approach works perfectly.
And I added my Acad version to my profile………..
You saved my ass, again,
Thanks a lot
Bernd
 :-D
« Reply #13 on: October 11, 2005, 05:52:31 AM »
My pleasure.
BTW. Saving a$$ is part of my job description. I have a cardboard box in my office, almost full.
Amsterdammed
« Reply #14 on: October 11, 2005, 05:54:06 AM »
Noo doubt  : :-)
