Author Topic: How would you......  (Read 6244 times)
One Shot
How would you......
« on: October 06, 2005, 04:54:23 PM »
How would you creates these line drawings for a masonry fireplaces to ADT and to be munipulated.  Do you have any examples to share.
Thank you,
Brad
Dommy2Hotty
Re: How would you......
« Reply #1 on: October 06, 2005, 05:33:37 PM »
Hurtz my noggin' just thinking about it...
pochrist
« Reply #2 on: October 11, 2005, 10:28:41 AM »
You can make this with a mass element, you can take the out line you have there and convert it to a Mass element, I'll attach an example, I'm using ADT 2005. shortly
Al
« Reply #3 on: October 11, 2005, 11:17:19 AM »
Here is my attempt in ADT, the blocking in your wall I can't do on the top view, :|  just the Sides, but show a section with a top view, if you had to do that with this ADT object you can generate a 2D Section and add the "X" on the blocking, hope this helps
pochrist
« Reply #4 on: October 11, 2005, 11:18:43 AM »
Sorry forgot the attachment
One Shot
« Reply #5 on: October 11, 2005, 11:25:24 AM »
Are mass element better to than wall modifiiers for this.  Are mass elements easy to modify?
Thank you,
Brad
pochrist
« Reply #6 on: October 11, 2005, 11:59:31 AM »
Thank you,
Brad
Mass elements are independent objects, they can have there own Display Representations, like walls do (Reflected, screened, etc), they are pretty easy to modify, Parametric controls like all AEC objects, they have vertex controls like slabs and walls and also use Solid "like" commands for Union, Subtract, etc.
They can also be used as body modifying of Walls.
It really depends on your need.  :-)
One Shot
« Reply #7 on: October 11, 2005, 12:01:39 PM »
Thank you very much! I haven't used mass elements that much.
