Author Topic: Search for text string in closed and zipped drawings  (Read 5385 times)
Re: Search for text string in closed and zipped drawings
« Reply #15 on: October 07, 2005, 10:00:08 AM »
Coffee, must get coffee.
 :oops:
« Reply #16 on: October 07, 2005, 12:22:36 PM »
Ok .. this is what I did ...
@echo off
::Change the next line to the root of where you want to start searching files
set BEGINPATH=X:\DWGS\OldDDrive\
echo Search will start in %BEGINPATH%
pause
::dir /a /s /b %BEGINPATH%*.ZIP > temp.txt
::extract all DWG files
For /F "tokens=1* delims= " %%f in ('dir /a /s /b %BEGINPATH%*.ZIP') do unzip.exe -j "%%f %%g" -d tmp/
::if there are any DWG files not compressed copy them as well
For /F "tokens=1* delims= " %%f in ('dir /a /s /b %BEGINPATH%*.DWG') do copy "%%f %%g" .\tmp
::search all DWG files
findstr "L0272" .\tmp\*.dwg
::now lets clean up behind ourselves
For /F "tokens=1* delims= " %%f in ('dir /a /s /b .\tmp\*.dwg') do erase "%%f %%g"
pause
set BEGINPATH=
The result was 8453 files searched took right at 2 hours to extract, search, and cleanup .... regardless of how long it took ... it certainly saved me hours upon hours of manual searching ...
« Reply #17 on: October 07, 2005, 03:02:39 PM »
So you found the dwg(s) okay then?
« Reply #18 on: October 07, 2005, 03:26:24 PM »
Actually I didn't find them ... but the tool did work for what it was designed to do ... anyway I will keep it handy for future use.
I'll likely expand it a bit and make it a little more user friendly ...
