Author Topic: Trapezoid question  (Read 932 times)
paulmcz
Trapezoid question
« on: October 06, 2005, 06:59:59 am »
Calculate "len" side
  • Mesozoic Relic
Re: Trapezoid question
« Reply #1 on: October 06, 2005, 07:06:55 am »
How about with just dim W ??
Discipline : absolutely none at all.
--> Donate to TheSwamp <--
  • Mesozoic Relic
« Reply #2 on: October 06, 2005, 07:11:19 am »
Is this a [Question:] type question that you know the answer to, or a real <normal> question ?
paulmcz
« Reply #3 on: October 06, 2005, 07:32:23 am »
I came across this problem recently and I had to find the answer. I found it quite interesting so I thought I would post it here as a bit of a challenge to some,
hendie
« Reply #4 on: October 06, 2005, 07:32:59 am »
I'm a bit rusty on this stuff ~ are you looking for an actual figure or just the formula ?
If the 3 Len's are equal, then the trapezoid must be formed from 3 equilateral triangles, therefore Len must be equal to 0.5*W, the acute angles must be 60° and the obtuse angles = 120°
therefore, h is easy to work out using Pythagoras' theory.... h = SQRT (Len² - ½w²)
of course I could be completely miles away here
Politics and the fate of mankind are shaped by men without ideals and without greatness. Men who have greatness within them don’t go in for politics.
Albert Camus Notebooks, 1935–42
Synergis Adept / Acad2004
  • Mesozoic Relic
« Reply #5 on: October 06, 2005, 07:39:20 am »
Consider it to be HALF of an Inclosed Polygon.
As Hendie mentioned the angles are 60 and 120 degrees.
The length len is equal to the circle radius, half of length W.
paulmcz
« Reply #6 on: October 06, 2005, 07:44:12 am »
formula, code, steps to draw it........ anything
  • Mesozoic Relic
« Reply #7 on: October 06, 2005, 07:50:27 am »
Whoa .. That will teach me to be presumptuous, shouldn't it
hendie
« Reply #8 on: October 06, 2005, 08:00:37 am »
ok, I'll take the easy route.
Draw a line X any length from A to B
Draw a circle at A of diameter 0.5*X
Draw a circle at B of diameter 0.5*X
Draw a circle using TAN, TAN, RADIUS from Circle 1 to Circle 2 and enter same radius as previous
Now draw line from A to first & second circles intersection, the to second & third circles intersection, then to point B
Done
if I had time I would code it but ...
  • Mesozoic Relic
« Reply #9 on: October 06, 2005, 08:29:58 am »
No Hendie, That wont do it.
I'm guessing it would need a simultanius equation of some form.
Imagine if the base is less than length LEN. The formulae would have to work in that case too.
It's past my bedtime. I'll probably dream about this paulmcz, not good !!
paulmcz
« Reply #10 on: October 06, 2005, 09:44:47 am »
You made my day man.   :lmao:  It happens to me very often.
paulmcz
« Reply #11 on: October 06, 2005, 09:58:32 am »
Done
Kerry is right Hendie, it won't do it.
CarlB
« Reply #12 on: October 06, 2005, 02:49:13 pm »
Steps to draw:
Draw base of length w.  Draw circles with R=len, centered on baseline endpoints.  Draw vertical line up from midpoint of baseline, arbitrary legth.  offet the line 1/2 len to each side.  Where the offset lines intersect the circles are the endpoints of the top of the trapezoid.
Tom
« Reply #13 on: October 06, 2005, 04:55:16 pm »
Draw a line any length - base line
from one end say left draw a circle rad @ half the line length
from same end draw a line "A" at 60 deg to base line passing over circle
from intersecting point draw a line "B" parralell to base line
mirror "A" about mid point of base line
trim overlaps and thats it
paulmcz
« Reply #14 on: October 06, 2005, 06:30:17 pm »
Steps to draw:
Can't draw circle with R=len untill we know "len" dimension. The only known is height (h) and width (w) of the baseline. Your method is fine only if "len" is known.
paulmcz
« Reply #15 on: October 06, 2005, 06:34:49 pm »
Baseline length is given (w) as well as height (h). Angle is not necessarily 60 deg (see second picture above). You are describing the case where nothing is given, except angle 60 deg.
CarlB
« Reply #16 on: October 07, 2005, 10:42:29 am »
Reading the question more closely this time..ready to take anothe stab at it;
Look at one of the triangles. Right triangle.  Call the hypotenuse L, height H, then the base is (W-L)/2.
Use the pythagorean theorum - the sum of the squares of the legs equals the square of the hypotenuse.  A little rearrangement gives you:
3L^2 +2LW - H^2 - W^2 = 0
Hey that's one equation, one unknown (L), should be solveable! And it's almost in the form of the quadratic equation,
ax^2 + bx + c = 0, which has the solution (going by memory here)...
x=[-b +/- sqrt(b^2 - 4ac]/2a
Now who's up to doing the math?
paulmcz
« Reply #17 on: October 07, 2005, 01:03:22 pm »
CarlB, I don’t think that this will get you there.
You'll be surprised how simple this problem is. There is no need for quadratic equation here. Just simple trigonometry is needed, if you want to solve it through the math.
Graphical solution is much easier, though. It takes less than a minute to draw it on the AutoCAD with absolute precision. You don’t even need the CAD to draw this very accurately.
CarlB
« Reply #18 on: October 07, 2005, 01:40:42 pm »
Bob, it's got to get me there, it's pure math!
(but I messed up in my first expression after substituting in the pythagorean eqn.)
So I followed through on the math, got:
L=[-W + 2 x sqrt (W^2 + 3H^2)]/3
Seemed to check out for an example drawin in CAD.
I'd love to see how to solve it graphically  :)
« Reply #19 on: October 07, 2005, 01:52:03 pm »
Here is my not so elegant solution :-):
(defun C:trap (/ pt ang len line1 line2 line3)
  (setq pt (getpoint "\n Pick start point: "))
  (setq len (getstring "\n Enter length: "))
  (setq ang (getstring "\n Enter angle: "))
  (setq line1 (strcat "@" len "<" ang))
  (setq line2 (strcat "@" len "<0"))
  (setq line3 (strcat "@" len "<-" ang))
  (command "_pline" pt line1 line2 line3 "close")
Windows 8 x64 - AutoCAD 2014
Dell Optiplex 9010 / Intel I7-3770 / 8GB RAM / NVidia 550ti
paulmcz
« Reply #20 on: October 07, 2005, 02:08:29 pm »
Ronjonp, we don't know the angle. Just "w" and "h" (see the picture in the first post)
paulmcz
« Reply #21 on: October 07, 2005, 02:20:16 pm »
You got it CarlB!
Here are the solutions I found.
Thanks for the ride.
Paul.
  • Mesozoic Relic
« Reply #22 on: October 08, 2005, 08:45:21 am »
Nice Solution Paul .. Well done Carl
