Author Topic: Array Question  (Read 7338 times)
LE
Re: Array Question
« Reply #15 on: October 07, 2005, 10:06:05 AM »
I think all bases are covered - Good job Michael
Re: Array Question
« Reply #16 on: October 07, 2005, 10:23:05 AM »
Thanks Louis, nice acknowledgement considering the source.  8-)
One thing I do want to say about this function (and a few others I've offered lately) --
(defun MatrixOmatic ( m n / *error* foo )
    (defun *error* (msg)
        (princ
            (strcat
                "Syntax: "
                (chr 40)
                "MakeMatrix m n"
                (chr 41)
                " where m and n are positive integers."
        (not
            (vl-every
               '(lambda (x)
                    (and
                        (eq 'int (type x))
                        (< 0 x)
                (list m n)
        (exit)
    (defun foo ( x / result )
        (   (lambda (k)
                (repeat x
                    (setq result
                        (cons
                            (setq k (1- k))
                            result
            (+ 0.5 (/ x 2.0))
    (apply 'append
        (mapcar
           '(lambda (y)
                (mapcar
                   '(lambda (x) (list x y))
                    (foo m)
            (foo n)
I normally don't provide the kind of hand holding, caller protected code you see therein and I would never place something like that in my libraries. It's good when you're starting out 'cause it identifies where you may have supplied invalid arguments; precisley why I penned it this way.
However, =in my opinion= code like this has no place in a library. Library code should be lean and mean -- if it gets passed invalid arguments it should crash; calling (hi level) code should deal with errors, not low level functions.
Do native lisp functions hand hold or crash I ask rhetorically? Put this in a lisp program and see what happens: (/ 1 0).
So my point is this, what I'd put in my library would be more like this:
(defun MatrixOmatic ( m n / foo )
        (   (lambda (k)
                (repeat x
                    (setq result
                        (cons
                            (setq k (1- k))
                            result
            (+ 0.5 (/ x 2.0))
    (apply 'append
        (mapcar
           '(lambda (y)
                (mapcar
                    (foo m)
            (foo n)
It's eactly what it needs to be and no more.
cadanalyst@gmail.com • http://cadanalyst.slack.com • http://linkedin.com/in/cadanalyst
LE
Re: Array Question
« Reply #17 on: October 07, 2005, 10:59:36 AM »
OK, I went to my very very old lisps and found this one [1992] it may be useful today, just excuse the style and the no default features.
What RECTGRID does is to paint rectangles row-column inside of a rectangle area, the user will be ask to define a rectangle area, and the number of rows and columns and the separation between them.... well see if it works today's
Have fun,
Luis
(defun C:RECTGRID
       (/ p1 p2 g k n m xo yo x y h l a b c d test sep osm olderr)
  (setq olderr *error*
*error* err
osm (getvar "OSMODE"))
  (setvar "CMDECHO" 0)
  (command "UNDO" "G")
  (setvar "OSMODE" 0)
  (setq P1 (getpoint "\nLower corner: ")
P2 (getcorner P1 "\nUpper corner: ")
N  (getint "\nNumber of columns (|||): ")
M  (getint "\nNumber of rows (--): "))
  (setq Xo (car P1)
Yo (cadr P1)
X  (- (car P2) Xo)
Y  (- (cadr P2) Yo))
  (setq tst T)
  (while tst
    (setq G (getdist "\nDistance between columns: "))
    (if (< G (setq SEP (/ (abs x) (+ N 1))))
      (setq tst nil)
      (prompt
(strcat "\nDistance must be lower than " (rtos SEP 2 3)))))
  (setq tst T)
  (while tst
    (setq K (getdist "\nDistance between rows: "))
    (if (< K (setq SEP (/ (abs y) (+ M 1))))
      (setq tst nil)
      (prompt
  (if (minusp x)
    (setq sx -1)
    (setq sx 1))
  (if (minusp y)
    (setq sy -1)
    (setq sy 1))
  (setq G (* sx G)
K (* sy K)
H (/ (- Y (* (+ M 1) K)) M)
L (/ (- X (* (+ N 1) G)) N)
A (list (+ Xo G) (+ Yo K))
B (list (+ Xo G L) (+ Yo K))
C (list (+ Xo G) (+ Yo K H))
D (list (+ Xo G L) (+ Yo K H)))
  (command "PLINE" A "W" 0 0 B D C A "")
  (if (and (= M 1) (= N 1))
    nil
      (command "ARRAY" (entlast) "" "R" M N)
((and (> M 1) (> N 1))
(command (+ H K) (+ L G)))
((and (= M 1) (> N 1))
(command (+ L G)))
((and (> M 1) (= N 1))
(command (+ H K))))))
  (command "UNDO" "E")
  (setvar "CMDECHO" 1)
  (setvar "OSMODE" osm)
  (setq *error* olderr)
  (princ))
(defun err  (s)
  (princ (strcat "\nError: " s))
  (princ))
Re: Array Question
« Reply #18 on: October 07, 2005, 11:39:01 AM »
Almost looks like it were made for laying out (concrete) piles Louis.
LE
Re: Array Question
« Reply #19 on: October 07, 2005, 11:42:09 AM »
It was the early stage for then another one.... to draw window elevations.... and yes it was in those days the original idea.... o man you definitely read minds [experience is shown from your part]....  :-o
Re: Array Question
« Reply #20 on: October 07, 2005, 11:47:20 AM »
... o man you definitely read minds ...
We should talk Louis, give me a call sometime: 1-800-LSP-JOJO.
:lmao:
LE
Re: Array Question
« Reply #21 on: October 07, 2005, 11:54:48 AM »
He he....
I have not put so much effort lately in lisp coding.... but yes, there must be a place for those lispaholic's or whatever that could sound in English.
I kept that phone number in case is needed it is a 24/7 service no?
Re: Array Question
« Reply #22 on: October 07, 2005, 12:13:45 PM »
Pretty close, probably 12/6.
t-bear
Re: Array Question
« Reply #23 on: October 08, 2005, 05:31:00 PM »
I tried that number.....kinky phone sex.......sounds just like MP......
Fatty
Re: Array Question
« Reply #24 on: October 09, 2005, 01:35:49 PM »
Hi Hudster
Sorry I badly know mathematics of an elementary school
Therefore I have solved a problem by means of standard
AutoCAD commands
Try as it will work for you
Thank you
F.
(defun C:tst  (/ cell col col_step coors cpt en mark
       mpt prot row row_dist row_step sset)
  (while (= (rem
      (setq row (getint "\n\tNumber of rows <odd number only> :\n\t"))
      2)
    0))
  (while (= (rem
      (setq col (getint "\n\tNumber of columns <odd number only> :\n\t"))
      2)
    0))
  (setq row_step (getreal "\n\tRow offset :\n\t")
col_step (getreal "\n\tColumn offset :\n\t")
cell (car (entsel "\nSelect object to array :"))
sset (ssadd)
  (setq row_dist (* (/ (1- row) 2) row_step)
coors (vl-remove-if
   (function not)
   (mapcar (function (lambda (x)
       (if (eq 10 (car x))
(trans (cdr x) 1 0))))
   (entget cell)))
cpt (mapcar '/ (mapcar '+ (car coors) (caddr coors)) '(2 2 2))
mpt (list (car cpt) (- (cadr cpt) row_dist) (cadr cpt)))
  (command "copy" cell "" '(0. 0. 0.) '(0. 0. 0.))
  (setq prot (entlast))
  (command "move" prot "" cpt mpt)
  (command "-array" prot "" "R" 1 (/ (1+ col) 2) col_step)
  (setq en (entnext prot))
  (ssadd en sset)
  (while (setq en (entnext en))
    (ssadd en sset)
;;;(sssetfirst nil sset);for test/debug only
;;;(sssetfirst);for test/debug only
  (setq mark (entlast))
  (ssdel prot sset)
  (command "mirror" sset "" cpt mpt "")
  (setq en (entnext mark))
  (ssadd en sset)
    (ssadd en sset)
  (ssadd prot sset)
  (command "-array" sset "" "R" row 1 row_step)
  (command "erase" cell "")
  (command "zoom" "e")
