Here is a semi-serious way to draw lines - parallel to each other by just moving the cursor to front or back to paint the lines.... this is just for fun....
Luis.
(setq 45Degrees (* pi 0.25))
(setq 90Degrees (* pi 0.5))
(setq 135Degrees (* pi 0.75))
(setq 225Degrees (* pi 1.25))
(setq 270Degrees (* pi 1.5))
(setq 315Degrees (* pi 1.75))
(setq 360Degrees (* pi 2.0))
(if (not *Acad)
(setq *Acad (vlax-get-acad-object)))
(defun thisDwg () (vla-get-activeDocument *Acad))
(setq
dtt_thisdwg
(cond (dtt_thisdwg)
((thisDwg))))
(if (not Model)
(setq Model
(vla-get-modelSpace dtt_thisdwg)))
(defun pSpace () (vla-get-paperSpace dtt_thisdwg))
(defun get-activeSpace ()
(if (= acModelSpace (vla-get-activeSpace dtt_thisdwg))
Model
(if (= (vla-get-mSpace dtt_thisdwg) :vlax-true)
Model
(pSpace))))
(defun lc-write2file (n / file p search)
(setq search (acadFolder))
(setq file (open (strcat search "$par$") "a"))
(write-line n file)
(close file))
(defun lc-readFile (/ file n tmp search)
(if (findfile (strcat search "$par$"))
(setq file (open (findfile (strcat search "$par$")) "r"))
(while (setq n (read-line file))
(if (/= n "")
(setq tmp (append tmp (list n)))))
(close file)))
tmp)
(defun lc-file2nil (/ search)
(vl-file-delete (findfile (strcat search "$par$")))
nil))
(defun acadFolder ()
(substr (findfile "acad.exe")
1
(- (strlen (findfile "acad.exe")) 8)))
(defun point2String (pt)
(strcat (rtos (car pt) 2 6)
(rtos (cadr pt) 2 6)
(rtos (caddr pt) 2 6)))
(defun rtd (a) (* (/ a pi) 180.0))
(defun lc-angle (/ p1 ang)
(setq p1 (getpoint "\n<Select LINE>/From point: "))
(if p1
(setq
ang (getangle
(strcat "\nAlignment angle <"
(rtos (rtd Atemp) 2 0)
p1))
(if (= ang nil)
(setq ang Atemp)
(setq Atemp ang))
(setvar "orthomode" 1)
(list ang p1))
nil))
(defun lc-vector (/ anglin ang p1 sep)
(setq sna (getvar "snapang"))
(setq anglin (lc-angle))
(if anglin
(setq ang (car anglin))
(setq p1 (cadr anglin))
(setvar "snapang" ang)
(setq size (getvar "cursorsize"))
(setvar "cursorsize" 1)
(initget 6)
(setq sep
(getdist p1
(strcat "\nTo point/Distance <"
(rtos ll)
(if (= sep nil)
(setq sep ll))
(if (not ll)
(setq ll 1.0))
(setq ll sep)
(if sna
(setvar "snapang" sna))
(if size
(setvar "cursorsize" size))
(list p1 (polar p1 ang sep)))
nil))
(defun addLine (start_point end_point / vla_line)
(if (and start_point
end_point
(not (vl-catch-all-error-p
(setq
vla_line
(vl-catch-all-apply
'vla-addLine
(list (get-activeSpace)
(vlax-3d-point start_point)
(vlax-3d-point end_point)))))))
vla_line))
(defun C:CLINE (/ p1 p2 p3 p4 sep lcopyent
entlist m s n c lst
obj take code5 mklin)
(if (not Atemp)
(setq Atemp 0.0))
(if (not ll)
(setq ll 1.0))
(lc-file2nil)
(setq lst nil)
(setq mklin (lc-vector))
(if (= mklin nil)
(setq obj (entsel "\nSelect line: "))
(progn (setq p1 (car mklin)) (setq p2 (cadr mklin))))
(if (and obj (= (cdr (assoc 0 (entget (car obj)))) "LINE"))
(setq lcopyent (car obj))
(setq
entlist (entget lcopyent)
p1 (cdr (assoc 10 entlist))
p2 (cdr (assoc 11 entlist)))))
(setq lst (lc-readFile))
(if (and p1 p2)
(if (and (not (member (point2String p1) lst))
(not (member (point2String p2) lst)))
(addLine p1 p2))
(if (not (member (point2String p1) lst))
(lc-write2file (point2String p1)))
(if (not (member (point2String p2) lst))
(lc-write2file (point2String p2)))
(setq lst (lc-readFile))))
(if p1
(setvar "orthomode" 0)
(initget 6)
(setq sep
(getdist
(strcat
"\nSelect two point/<Distance between them = "
(rtos ll)
(if (= sep nil)
(setq sep ll))
(if (not ll)
(setq ll 1.0))
(setq ll sep)))
(if (and p1 p2 sep)
(prompt
"\n<ENTER to exit>/Move cursor to copy")
(while (not (equal (setq take (grread 't)) '(2 13)))
(setq code5 (car take))
(setq p3 (cadr take))
(if (and p3 (= 5 code5))
(setq
p4
(inters p1
p2
p3
(polar p3
(+ (angle p1 p2) 90Degrees)
1.0)
nil))
(setq
p1 (polar p1 (angle p4 p3) sep)
p2 (polar p2 (angle p4 p3) sep))
(if (and p1 p2)
(and
lst))
lst)))
(addLine p1 p2))
(lc-write2file (point2String p2))))))
(prompt
"\r<ENTER to exit>/Move cursor to copy")
(alert
"\nWork on current window, other command are disabled\nUse mouse scroll button to zoom in out or pan."))))))
(setvar "snapang" 0.0)
(princ))
(princ "\nCLINE by www.geometricad.com ")
