Author Topic: vla-item with attributes  (Read 2023 times)
whdjr
« on: October 03, 2005, 01:04:11 PM »
I have a list of AttributeReferences (call it ListA) and reference AttributeReference (call it RefAtt).
How would I use 'vla-item' to return the AttributeReference from ListA that matched the same 'tagstring' with the RefAtt?
Or is there another function I should be using?
Re: vla-item with attributes
« Reply #1 on: October 03, 2005, 01:15:33 PM »
vla-item is used on collections, not lists.
IF, and that's a big IF, ListA is a true list of AttributeReference objects and RefAtt is an AttributeReference object then perhaps this ...
(setq result
        (lambda ( / tagstring )
            (setq tagstring
                (strcase
                    (vla-get-tagstring
                        RefAtt
            (vl-remove-if-not
               '(lambda (attributeReference)
                    (eq tagstring
                        (strcase
                            (vla-get-tagstring
                                attributeReference
                ListA
Coded blind, so may need massaging.
whdjr
« Reply #2 on: October 03, 2005, 01:49:10 PM »
Thanks MP,
I knew I could do it with vl-remove-if-not but thought I could do it better with vla-item.  I'll try to implement your code and see what I get.
Thanks, :-)
« Reply #3 on: October 04, 2005, 07:52:32 AM »
You may find some useful code in this routine.
http://www.theswamp.org/forum/index.php?topic=6741.msg83413#msg83413
