Author Topic: Diffuser lisp  (Read 6180 times)
Royalchill
Diffuser lisp
« on: October 03, 2005, 11:22:09 AM »
I am looking for a lisp routine that will let me insert a diffuser/grille to the size I specifie, like an 8x6, 12x8 etc. plus create a layer name. Any help email me gab@sweng.com. Thanks alot
hudster
Re: Diffuser lisp
« Reply #1 on: October 03, 2005, 11:27:47 AM »
why not draw it 1mm by 1mm, then scale it to the size you want, 400, 400 etc etc.
Thats what I do for these things.
Re: Diffuser lisp
« Reply #2 on: October 03, 2005, 11:35:04 AM »
This is the wrong place for this post. ...I will be moving it to the AutoLisp forum.
*SMACK!*
Re: Diffuser lisp
« Reply #3 on: October 03, 2005, 11:36:28 AM »
We have now arrived at our final destination, I hope everyone enjoyed the ride.
t-bear
Re: Diffuser lisp
« Reply #4 on: October 03, 2005, 01:28:12 PM »
Blocks library!?!   Once made, you never need draw one again............just a thought.
hyposmurf
Re: Diffuser lisp
« Reply #5 on: October 03, 2005, 02:26:20 PM »
If your on 2004 upwards then create a drawing of them all, then use this to create a tool pallete, as far as I remember you can preset the layer for them to.
  • Custom Title
Re: Diffuser lisp
« Reply #6 on: October 03, 2005, 03:36:46 PM »
This will get you started.
(defun c:diffu (/ pt_int ang size_h size_w pt_tmp pt_t1 pt_t2 pt_t3
pt_t4)
  (command "_.layer" "Make" "_diffuser" "")
  (if (setq pt_int (getpoint "\nPick Insertion Point: "))
    (if (setq ang (getangle pt_int "\nAngle: "))
      (if (setq size_h (getreal "\nHeight: "))
(if (setq size_w (getreal "\nWidth: "))
    (setq pt_tmp (polar pt_int ang (/ size_h 2))
  pt_t1 (polar pt_tmp (+ ang (* pi 0.5)) (/ size_w 2))
  pt_t2 (polar pt_t1 (angle pt_tmp pt_int) size_h)
  pt_t3 (polar pt_t2 (angle pt_t1 pt_tmp) size_w)
  pt_t4 (polar pt_t3 (angle pt_int pt_tmp) size_h)
    (command "_.LINE" pt_t1 pt_t2 pt_t3 pt_t4 "CLOSE")
Adesu
Re: Diffuser lisp
« Reply #7 on: October 04, 2005, 09:40:26 PM »
As add corrected,here this code
(defun c:diffu (/ lay pt_int ang size_h size_w pt_tmp pt_t1 pt_t2 pt_t3 pt_t4)
  (setq lay (tblsearch "layer" "_diffuser"))
    (not lay)                                                 ; Check to see correct layer exists
    (command "-layer" "n" "_diffuser" "c" "1" "_diffuser" "s" "_diffuser" ""); if not, create/set it
    (command "-layer" "s" "_diffuser" "")                          ; if it does, set it current
  ;(command "_.layer" "Make" "_diffuser" "")
pt_t4)
Re: Diffuser lisp
« Reply #8 on: October 04, 2005, 09:49:40 PM »
 Not meaning to be antagonistic, but ..
Why change this :
To This ??
.. and call it a correction ?? ???
Re: Diffuser lisp
« Reply #9 on: October 04, 2005, 09:55:19 PM »
I am with you Kerry ... I wouldn't call it a correction ... but ... it DOES clean up the command line output in the event the layer already exists ...
Re: Diffuser lisp
« Reply #10 on: October 04, 2005, 10:04:11 PM »
The command line clutter can be fixed with setting CMDECHO to 0.
Mark <I believe> used the same procedure I would for test demo code.
The MAKE command for layer does just that .. makes it if not existing, and makes it current.
To my mind, the changes to Mark's code would be confusing to someone who is trying to grasp the fundamentals of Lisp.
A more productive addition would be a generic stand alone helper routine which could be passed the layer properties.
« Last Edit: October 04, 2005, 10:07:22 PM by Kerry Brown »
Re: Diffuser lisp
« Reply #11 on: October 04, 2005, 10:16:26 PM »
For the most part you are indeed correct, however this is not the way it works on some older versions of AutoCAD. An error is produced along the lines of "Layer already exists" and this output is unaffected by CMDECHO. I used to rewrite code many times that had this output, simply to rid the command line of unneeded output.
Re: Diffuser lisp
« Reply #12 on: October 04, 2005, 10:24:32 PM »
Thats interesting Keith.
Which Version of Acad causes an error.
Re: Diffuser lisp
« Reply #13 on: October 04, 2005, 10:36:59 PM »
I don't recall seeing that error in anything after 2002, but prior to that I had it quite regularly ... in one application I redesigned (it was R14 if my mind serves me correctly) the user created around 140 layers with a command ... sometimes the layers existed sometimes they did not, but everytime the command was used there would be output anywhere from 0 to 140 lines telling the user the layer already existed,  even though cmdecho was set to 0. Instead of checking for the existence of 140 layers, I finally decided it would be easier to simply create a blank drawing with all of the layer settings and insert it with the routine instead of create the layers programmatically, but then that was a unique situation ... I would typically use a lambda function to iterate through large numbers of layers, but alas, some people don't understand lambda and cringe whenever it is used (as was the project manager on this project)
Anyway, after some research, I don't think it is sonething that users would need to worry with if they are using a relatively new version of AutoCAD.
Re: Diffuser lisp
« Reply #14 on: October 04, 2005, 10:51:06 PM »
I seem to recall R12 having the same "MAKE" functionality as the current version.
... anyway, you are correct that this probably isn't an issue.
To be practical ..
Attempting to Draw onto LOCKED Layers is probably a bigger issue ..
