Author Topic: ssget filter errors  (Read 6489 times)
whdjr
ssget filter errors
« on: October 01, 2005, 12:14:56 PM »
Why does this not work?
Are you allowed to put handles in your ssget filters?
(ssget '((0 . "INSERT")
          (66 . 1)
          (2 . "R-NAME")
          (-4 . "<NOT")
          (5 . "345AD7"))
It gives me an error 63 (filter error) when I try to run it.  I tried the '<not' before and after the handle with no luck.  It only works without the handle.  Can anyone verify this for me?
Peter Jamtgaard
Re: ssget filter errors
« Reply #1 on: October 01, 2005, 12:36:34 PM »
Try this. The not filter requires 2 parts
It might work
          (66 . 1)
          (2 . "R-NAME")
          (-4 . "<NOT")
          (5 . "345AD7")
          (-4 . "NOT>"); revised
« Last Edit: October 01, 2005, 12:44:49 PM by Peter Jamtgaard »
whdjr
« Reply #2 on: October 01, 2005, 01:02:21 PM »
It might work
No go.  I tried that already but I tried it again and it still didn't work.
LE
« Reply #3 on: October 01, 2005, 01:19:39 PM »
You cannot use group 5 with ssget.... it won't be recognize.... that's why
« Reply #4 on: October 01, 2005, 01:25:32 PM »
You cannot filter on group 5, you have to do something like this --
(defun RemoveHandlesFromSS ( ss handles / i ename )
    (setq handles (mapcar 'strcase handles))
    (if (eq 'pickset (type ss))
        (repeat (setq i (sslength ss))
                (member
                    (cdr
                        (assoc 5
                            (entget
                                (setq ename
                                    (ssname ss
                                        (setq i (1- i))
                    handles
                (ssdel ename ss)
    ss
Then --
(setq ss
    (RemoveHandlesFromSS
        (ssget
           '(   (0 . "INSERT")
                (66 . 1)
                (2 . "R-NAME")
       '("345AD7")
Coded blind so may need massaging.
« Reply #5 on: October 01, 2005, 01:37:11 PM »
Think you have it backwards Luis, he DOESN'T want the entity sporting that handle.
« Reply #6 on: October 01, 2005, 01:43:54 PM »
Scratching Head
If the handle is unique then he does want a specific object, no? :?
« Reply #7 on: October 01, 2005, 01:46:58 PM »
Looks to me like he wants all blocks named "R-NAME" that have attributes except the one with the handle "345AD7", at least that is what the code in the first post suggests to me.
« Reply #8 on: October 01, 2005, 01:49:37 PM »
Oh, I missed the NOT. :-o
In that case your solution look perfect for that.
« Reply #9 on: October 01, 2005, 02:03:59 PM »
Something a little more flexible might be --
(defun RemoveFromPicksetIf ( ss func )
    ;;  The supplied func must take one
    ;;  argument, an ename. What it does
    ;;  we don't care, but if it returns
    ;;  a non nil result remove the entity
    ;;  from the pickset
                (func
                    (setq ename
                        (ssname ss
                            (setq i (1- i))
                (ssdel ename ss)
    ss
Then he'd might use it thusly --
(setq ss
    (RemoveFromPicksetIf
        (ssget
           '(   (0 . "INSERT")
                (2 . "R-NAME")
                (66 . 1)
        (lambda (ename)
            (eq "345AD7"
                (cdr
                    (assoc 5
                        (entget ename)
whdjr
« Reply #10 on: October 01, 2005, 02:32:16 PM »
Thanks guys you answered my question and gave more as always.
What I did while I was waiting was to get the entities supplied from 'ssget' and then used 'vl-remove' to remove the entity I didn't need because I already had the entity name from earlier in my code.  I was just trying to shorcut that by ecluding that block via it's handle; but that's a no go.
Thanks again guys.
Crank
« Reply #11 on: October 01, 2005, 02:36:55 PM »
(ssdel (handent "345AD7") (ssget '((0 . "INSERT")(66 . 1)(2 . "R-NAME"))))
« Reply #12 on: October 01, 2005, 02:38:07 PM »
Good stuff Mr. Crank. For succinctness that's a winner.
whdjr
« Reply #13 on: October 01, 2005, 10:30:56 PM »
I Like!  :-)
« Reply #14 on: October 02, 2005, 11:42:15 AM »
Make sure you use a valid handle for the succinct version lest there be an immediate "earth shattering kaboom".
/Marvin
:lol:
