Author Topic: Leader [vertical text]  (Read 4430 times)
« on: January 29, 2004, 09:15:32 AM »
Looking at the attached image, does anyone know how to make the standard leader use vertical text?
hendie
« Reply #1 on: January 29, 2004, 09:17:07 AM »
rotate your monitor through 90 °   ?
hyposmurf
« Reply #2 on: January 29, 2004, 09:26:51 AM »
Not what you exactly looking for but you could just create a quick leader horizontally and rotate the lot.There doesnt appear to be anything in the settings for horizontal text.
Dent Cermak
« Reply #3 on: January 29, 2004, 09:55:16 AM »
You have heard my tales of woe about not being able to use my LDD3 yet, so I am no expert on the newer AutoCAD by any means. BUT, what happens when you go to "DIMSTYLE" , to the style manager, select the "text" tab, go down to the "Text Placement" block, and set the vertical window to "above"?? That sounds too simple to work though.
Never mind. I just tried that and it didn't work. The only way I have found to do it so far is to set the leader and text at 0 degrees and then rotate them both 90 degrees. Not a good answer. Give Keith a minute and he will have you a lisp thingie.
« Reply #4 on: January 29, 2004, 10:21:42 AM »
^C^Cdview;;tw;-90;;_ucs;w;_ucs;z;90;_qleader;^C^C-view;top; :)
« Reply #5 on: January 29, 2004, 10:11:32 PM »
well, since CAB beat me to it, I let it ride for a while, but how is thisfor a slight improvement...
put this in a button
^C^C_ucs;z;90;_qleader;^C^C_ucs;z;-90
Now the entire view does not rotate, only the UCS,  then it rights itself back to the same exact look as before the ucs change.
« Reply #6 on: January 30, 2004, 05:06:06 AM »
Thanks I'll give those try.
Odon
« Reply #7 on: January 30, 2004, 10:12:39 AM »
You could create a new dimension style and suppress dim line 2 and both extension lines.  Use linear to place the dimension (leader).
Odon
